Comprehensive SSL certificate monitoring with Discord alerts and Notion integration
Created by: Tom Cao || tomcao
Tom Cao
Last update 23 days ago
Categories
🔐 Advanced SSL Health Monitor
👤 Who is this for?
This workflow is designed for DevOps engineers, IT administrators, and security professionals who need comprehensive SSL certificate monitoring and health assessment across multiple domains — featuring dual verification and professional reporting without relying on expensive monitoring services.
🧩 What It Does
  1. Daily Trigger runs the workflow every morning for proactive monitoring.
  2. URL Collection fetches the list of website URLs to monitor from your data source.
  3. Dual SSL Analysis:
  4. Comprehensive Health Check:
    • Certificate expiration monitoring (customizable threshold)
    • SSL configuration security assessment
    • Protocol support analysis (TLS 1.3, 1.2, deprecated protocols)
    • Cipher suite strength evaluation
    • Vulnerability scanning (POODLE, BEAST, etc.)
    • Compliance checking (PCI DSS, NIST, FIPS)
  5. Smart Alert System sends Discord notifications when:
    • Certificates expire within threshold (default: 30 days)
    • SSL configuration issues detected (weak ciphers, deprecated protocols)
    • Security vulnerabilities found
    • Compliance standards not met
    • Grade drops below acceptable level (configurable)
🎯 Key Features
  • 🔄 Dual Verification: Cross-checks results between internal scanner and external API
  • 📊 SSL Labs-Style Grading: A+ to F rating system with detailed analysis
  • 🛡️ Security Assessment: Vulnerability detection and compliance checking
  • 📱 Discord Integration: Rich embed notifications with color-coded alerts
⚙️ Setup Instructions
  1. Data Source:
    • Configure your URL source from Notion
    • Ensure it contains a URL column with domains to monitor
  2. Credentials:
    • Set up Discord webhook for alert notifications
    • Configure any required API credentials for data sources
  3. Customize Thresholds:
    • Expiration Alert: Days before expiry (default: 30 days)
    • Grade Threshold: Minimum acceptable SSL grade (default: B)
    • Alert Severity: Choose which issues trigger notifications
  4. Advanced Configuration:
    • Modify vulnerability checks based on your security requirements
    • Adjust compliance standards for your industry needs
    • Customize Discord message formatting and alert channels
🧠 Technical Notes
  • Dual-Check Reliability: Combines custom Bubobot scanner with ssl-checker.io for maximum accuracy
  • No Vendor Lock-in: Uses free public APIs and open-source tools
  • Professional Reporting: Generates SSL Labs-quality assessments
  • Security-First Approach: Comprehensive vulnerability and compliance checking
  • Flexible Alerting: Discord integration with rich formatting and conditional logic
This workflow provide a comprehensive SSL security monitoring solution that rivals enterprise-grade tools while remaining completely open-source and free.
