Fetch hierarchical data records from Airtable with multi-level relationships
Created by: digi-stud.io || valerian
digi-stud.io
Last update a month ago
Categories
Airtable Hierarchical Record Fetcher
Description
This n8n workflow retrieves an Airtable record along with its related child records in a hierarchical structure. It can fetch up to 3 levels of linked records and assembles them into a comprehensive JSON object, making it ideal for complex data relationships and nested record structures.
Features
  • Multi-level Record Fetching: Retrieves parent record, linked child records (level 2), and optionally grandchild records (level 3)
  • API Call Optimization: Uses Airtable's filterByFormula to minimize API calls by fetching multiple related records in single requests
  • Selective Level 3 Fetching: Only fetches level 3 records for specified linked fields to optimize performance
  • Rich Text Processing: Converts Airtable's pseudo-markdown rich text fields to HTML format
  • Hierarchical JSON Output: Organizes all data in a structured, nested JSON format
  • Flexible Configuration: Customizable depth and field selection per execution
Input Parameters
The workflow accepts a JSON array with the following structure:
    "base_id": "appN8nPMGoLNuzUbY",
    "table_id": "tblLVOwpYIe0fGQ52",
    "record_id": "reczMh1Pp5l94HdYf",
    "level_3": [
      "fldRaFra1rLta66cD",
      "fld3FxCaYk8AVaEHt"
    "to_html": true
Parameter Details
Parameter Type Required Description
base_id string Yes Airtable base identifier
table_id string Yes Airtable table identifier for the main record
record_id string Yes Airtable record identifier to fetch
level_3 array No Array of field IDs from level 2 records for which to fetch level 3 children
to_html boolean No Convert rich text fields from pseudo-markdown to HTML (default: false). This requires marked npm package.
Output Structure
The workflow returns a hierarchical JSON object with the following structure:
   "id": "recXXXXXXX",
   "field_1": ...,
   "field_2": ...,
   "level2_child": [
         "id": "recXXXXXXX",
         "field_a": ...,
         "field_b": ...,
         "level3_child": [
               "id": "recXXXXXXX",
               "field_y": ...,
               "field_z": ...,
