Automatic Typebot flows two-way sync with GitHub using Typebot API
Created by: Marcial Ambriz || marskdev
Marcial Ambriz
Last update a month ago
Categories
Remixed Backup your workflows to GitHub from Solomon's work. Check out his templates.
This workflow will backup your typebots to GitHub. It uses the Typebot API to export all typebots.
It then loops over the data, checks in GitHub to see if a file exists that uses the credential's ID. Once checked it will:
  • update the file on GitHub if it exists;
  • create a new file if it doesn't exist;
  • ignore if it's the same.
In addition, it also checks if any flow have been deleted from typebot workspace. If a flow no longer exists in workspace, the corresponding file will be removed from the repository to keep everything in sync.
Who is this for?
People wanting to backup their typebots(flows) outside the server for safety purposes or to migrate to another server.
