Scrape developer profiles from Stack Overflow for lead generation with OpenAI & Bright Data
Yaron Been
Last update 7 months ago
This workflow contains community nodes that are only compatible with the self-hosted version of n8n.
This workflow automatically discovers and collects information about Stack Overflow user profiles for lead generation. It saves you time by eliminating the need to manually browse through developer profiles and provides a centralized database of potential leads with their technical expertise.
Overview
This workflow automatically scrapes Stack Overflow user profiles and extracts key information like developer names, locations, reputation scores, and technical tags. It uses Bright Data to access Stack Overflow without being blocked and AI to intelligently parse user data into structured format.
Tools Used
  • n8n: The automation platform that orchestrates the workflow
  • Bright Data: For scraping Stack Overflow user profiles without being blocked
  • OpenAI: AI agent for intelligent data extraction and parsing
  • Google Sheets: For storing and organizing lead information
How to Install
  1. Import the Workflow: Download the .json file and import it into your n8n instance
  2. Configure Bright Data: Add your Bright Data credentials to the MCP Client node
  3. Set Up OpenAI: Configure your OpenAI API credentials
  4. Configure Google Sheets: Connect your Google Sheets account and specify the target spreadsheet
  5. Customize: Adjust the Stack Overflow URL and user criteria you want to target
Use Cases
  • Recruitment Teams: Find developers with specific technical skills for hiring
  • Business Development: Identify potential clients or partners in the tech industry
  • Sales Teams: Build targeted outreach lists for developer-focused products
  • Research: Gather data on developer communities and skill distributions
Connect with Me
#n8n #automation #stackoverflow #leadgeneration #brightdata #webscraping #developers #recruitment #businessdevelopment #salesleads #n8nworkflow #workflow #nocode #leadautomation #developerscraping #techtalent #userprofiles #aiautomation #datamining #prospecting #outreach #techrecruiting #developerleads #stackoverflowscraping #profilescraping #leadcollection #techcommunity #developerdatabase #automatedleads #intelligentscraping
