Extract & analyze competitor backlink data with Bright Data MCP & GPT
Yaron Been
Last update a month ago
This workflow contains community nodes that are only compatible with the self-hosted version of n8n.
This workflow automatically analyzes competitor backlink profiles to understand their link building strategies and identify opportunities for your own SEO efforts. It saves you time by eliminating the need to manually research competitor links and provides detailed insights into their most valuable linking relationships.
Overview
This workflow automatically scrapes backlink analysis tools and competitor websites to extract comprehensive backlink data including referring domains, anchor text, link quality metrics, and link acquisition patterns. It uses Bright Data to access backlink databases and AI to intelligently analyze competitor link strategies.
Tools Used
  • n8n: The automation platform that orchestrates the workflow
  • Bright Data: For scraping backlink analysis platforms without being blocked
  • OpenAI: AI agent for intelligent backlink strategy analysis
  • Google Sheets: For storing competitor backlink data and insights
How to Install
  1. Import the Workflow: Download the .json file and import it into your n8n instance
  2. Configure Bright Data: Add your Bright Data credentials to the MCP Client node
  3. Set Up OpenAI: Configure your OpenAI API credentials
  4. Configure Google Sheets: Connect your Google Sheets account and set up your backlink analysis spreadsheet
  5. Customize: Define competitor domains and backlink analysis parameters
Use Cases
  • SEO Strategy: Learn from competitor link building success and replicate strategies
  • Link Prospecting: Identify websites that link to competitors but not to you
  • Competitive Intelligence: Understand competitor SEO strategies and authority sources
  • Link Building: Find high-quality link opportunities in your industry
Connect with Me
#n8n #automation #competitorbacklinks #backlinkanalysis #seo #linkbuilding #brightdata #webscraping #competitoranalysis #n8nworkflow #workflow #nocode #linkanalysis #backlinkresearch #seoanalysis #competitiveintelligence #linkresearch #seostrategy #backlinkmonitoring #linkprospecting #domainanalysis #seotools #backlinkaudit #linkbuilding #organicseo #searchmarketing #competitorresearch #linkstrategy #seocompetitor #backlinkinsights
