Save & summarize articles from Telegram to Notion using GPT-4o
Created by: Yosua Surojo || arthurmorgan25
Yosua Surojo
Last update 12 days ago
Who it's for
This workflow is for anyone who wants to build an automated, AI-enhanced reading list. Ideal for:
  • Knowledge workers and researchers who collect and organize articles
  • Students managing study materials
  • Productivity hackers who use Telegram and Notion for personal knowledge management
  • Anyone using the AI-Enhanced Knowledge Base Tracker Notion Template
This workflow takes any article link sent to your Telegram bot and automatically:
  • Parses the article into a clean title and body
  • Uses OpenAI to generate a 1–2 sentence highlight and topic tag
  • Saves it into your Notion database
  • Sends a confirmation message with the highlight and Notion link back to Telegram
Main steps:
  1. Telegram Trigger - Listens for incoming message containing an article link.
  2. Fetch Article Title & Content - Calls the article-parser-api deployed on Vercel to fetch and parse the article content into structured JSON (title and content).
  3. Generate Highlight + Tag (AI Agent) - Processes the parsed content to generate Highlight and Type tag values.
  4. Structured Metadata for Notion - Adjusts the extracted data before saving it to Notion.
  5. Save Article to Notion Database - Inserts the article and generated metadata into your Notion knowledge base.
  6. Confirm Save via Telegram - Sends a confirmation message and the Notion page link back to the Telegram bot chat after the entry is created.
  1. Create and connect your API credentials:
  2. Deploy the article parser:
  3. Link your Notion database:
  4. Test your workflow:
    • Click Execute workflow
    • Send an article link to your Telegram bot
  5. Once verified, activate the workflow so it runs automatically
Requirements
  • Telegram bot token
  • OpenAI API key
  • Notion integration and shared database
  • A deployed article parser (e.g., article-parser-api)
Optional customization
  • Edit the AI Agent prompt to change tone or tagging style
  • Add filtering or additional fields in the Edit Fields node
  • Trigger from other sources (e.g., Slack or Email)
