Track flight fares with Amadeus & Skyscanner - alerts, refunds & trends
Last update 22 days ago
Categories
This automated n8n workflow tracks booked flight fares post-purchase using Amadeus and Skyscanner APIs to detect drops for refund or credit opportunities. It streamlines fare monitoring, updates booking statuses, and notifies users via SMS or email.
Fundamental Aspects
  • Fare Check Trigger - Initiates the workflow
  • Get Tracked Bookings - Retrieves existing booking data
  • Prepare Fare Query - Prepares query parameters
  • Search Current Fares - Queries Skyscanner for current fares
  • Analyze Fare Drops - Identifies significant fare reductions
  • Update Fare Tracking - Updates fare tracking records
  • Update Booking Status - Updates status based on fare changes
  • Check if Notification Needed - Determines if alerts are required
  • Send Fare Drop Email - Notifies users via email
  • Notify Slack Team - Alerts the team via Slack
  • Check Refund Eligible - Assesses refund eligibility
  • Initiate Refund Process - Starts refund procedure if eligible
  • Check if SMS Needed - Decides if SMS alert is necessary
  • Send SMS Alert - Sends SMS notification
Setup Instructions
  1. Import the workflow into n8n
  2. Configure API credentials for Amadeus and Skyscanner
  3. Run the workflow
  4. Verify notifications and refund processes
Features
  • Fare Monitoring - Tracks and compares fares using Amadeus and Skyscanner
  • Alert System - Sends email and SMS notifications for fare drops
  • Refund Management - Checks and initiates refund processes
  • Trend Analysis - Analyzes fare trends for strategic decisions
DB Queries
  • Get Tracked Bookings Columns: - booking_id, passenger_name, email, phone, flight_number, departure_date, origin, destination, airline, booking_class, original_fare, booking_date, confirmation_code, tracking_enabled, last_checked, current_lowest_fare, trend.
  • Update Fare Tracking Columns: - booking_id, check_date, lowest_fare, fare_source, savings_amount, savings_percentage, fare_trend, priority_level, action_recommended, refund_eligible, available_fares_json, updated_at.
  • Update Booking Status: Columns - last_checked, current_lowest_fare, booking_id.
DB Setup:
  • Create tables 'bookings' and 'fare_tracking' with above columns, set 'booking_id' as primary key, and ensure proper indexing for performance.
  • Run queries after configuring DB connection in n8n with appropriate credentials.
Parameters to Configure
  • amadeus_api_key: Amadeus API key
  • skyscanner_api_key: Skyscanner API key
  • email_recipients: List of email addresses for alerts
  • sms_recipients: List of phone numbers for SMS alerts
  • slack_channel: Slack channel for team notifications
  • refund_threshold: Minimum fare drop for refund eligibility
