Extract organizations & summarize documents with Foxit and Diffbot
Created by: Raymond Camden || raymondcamden
Raymond Camden
Last update a month ago
How It Works
This N8N template demonstrates using Foxit's Extraction API to get information from an incoming document and then using Diffbot's APIs to turn the text into a list of organizations mentioned in the document and create a summary.
  • Listen for a new file added to a Google Drive folder. When executed, the bits are downloaded.
  • Upload the bits to Foxit.
  • Call the Extract API to get the text contents of the document.
  • Poll the API to see if it's done, and when it is, grab the text.
  • Send the text to Diffbot API to get a list of entities mentioned in the doc as well as the summary.
  • Use a code step to filter the entities returned from Diffbot to ones that are organizations, as well as filtering to a high confidence score.
  • Use another code step to make an HTML string from the previous data.
  • Email it using the GMail node.
Requirements
Next Steps
This workflow assumes PDF input, but Foxit has APIs to convert Office docs to PDF and that flow could be added before the Extract API is called.
Diffbot returns an incredible set of information and more could be used in the email.
Instead of emailing, you could sort documents by organizations into new folders.
