Archive trending TikTok hashtags using TikTok, Airtable, and Apify
Created by: Fahmi Fahreza || fahmiiireza
Fahmi Fahreza
Last update a month ago
Categories
Archive Trending TikTok Hashtags to Airtable with Apify
This template uses a community node (@apify/n8n-nodes-apify). It will not work without the required node installed.
Who it's for
Social Media Managers & Content Creators
Discover relevant hashtags and build content calendars based on real trends.
Marketing & Brand Strategists
Track cultural shifts and find opportunities by understanding regional audience interests.
Data Analysts
Create a dataset for analyzing hashtag trends, virality, and performance over time.
What it does
This workflow automates trend discovery and data collection from TikTok into Airtable.
  • Schedule: Triggers automatically once a month.
  • Scrape: Runs an Apify Actor to scrape TikTok’s top 100 trending hashtags for a specified country (default is US).
  • Retrieve: Fetches the dataset with hashtag metrics after scraping completes.
  • Process & Load: Splits the dataset and saves each hashtag as a new record in Airtable with relevant details.
How to set it up
1. Install the Community Node
Go to Settings; Community Nodes on your n8n instance and install @apify/n8n-nodes-apify.
2. Prepare Airtable
Create a base with a table named Trending Hashtags:
  • ID
  • Name
  • Country
  • Industry
  • Date Added
  • Publish Count
  • Video Views
  • Rank
  • Status
3. Add Credentials
Add your Apify and Airtable credentials in n8n.
4. Configure Scraper (Optional)
Open the 1. Run TikTok Hashtag Scraper node.
In the Custom Body, you can adjust:
  • country_code (e.g., "US" to "GB")
  • top100_period (e.g., "30" to "7")
5. Configure Airtable Node
Open the 4. Save Hashtag to Airtable node.
Select the correct Airtable Base and the Trending Hashtags table.
6. Activate Workflow
Save and activate the workflow. It will now run automatically every month.
Requirements
  • Installed community node: @apify/n8n-nodes-apify
  • Apify account
  • Airtable account with a structured base
How to customize the workflow
Change Schedule
Modify the Start: Monthly Schedule node to run weekly or on another interval.
Add Notifications
Attach a Slack or Discord node after the 4. Save Hashtag to Airtable node to alert your team when new data is added.
Filter Hashtags
Use a Filter node after 3. Split Hashtags into Items to only save hashtags that meet specific conditions (e.g., over 1M video views).
