Ai-powered bug tracking with GitHub issues and Telegram alerts using Gemini
Created by: Rully Saputra || rullysaputra15
Rully Saputra
Last update a month ago
Create GitHub issues from webhook input and send alerts to Telegram
This workflow streamlines bug tracking by using a webhook to collect issue reports, automatically classifying and summarizing them with Gemini AI, then sending critical issues to GitHub and real-time notifications to Telegram. Optional manager approval is built in for low-priority reports.
🧑‍💻 Who’s it for
This workflow is ideal for:
  • Engineering teams needing automated issue tracking from multiple systems
  • QA testers or customer support agents who log bugs via custom tools
  • DevOps teams monitoring logs or error reports in real time
  • Teams using GitHub for issue tracking and Telegram (or any messenger) for notifications
⚙️ How it works
Webhook Trigger – Listens for incoming POST requests containing bug or task data.
AI-Powered Classification – Uses the Gemini model to classify bugs as High or Low severity.
Optional Approval – If severity is Low, it waits for a manager’s approval before proceeding.
Bug Summary Generation – Passes through a filter and sends the input to Gemini to generate a clean summary.
Create GitHub Issue – Submits the summarized issue to your GitHub repository.
Telegram Notification – Sends a formatted message to a Telegram group or manager, depending on the path.
🛠️ How to set up
  • Replace the GitHub node with your repo credentials and target repo.
  • Set up the Telegram bot token and chat ID in the Telegram node.
  • Customize the Gemini prompts for your preferred classification and summary logic.
  • Define the conditions for “High” vs “Low” severity based on your data.
📋 Requirements
  • A GitHub account with a personal access token (with repo access)
  • A Telegram bot token and group chat ID
  • Google Gemini API credentials (or your preferred AI model integration)
🔧 How to customize the workflow
  • Swap Telegram with another messaging platform like Slack, Discord, or Microsoft Teams.
  • Adjust classification rules to match your business logic.
  • Change approval flow to notify a different person or add additional logic before sending to GitHub.
  • Extend the webhook input format to support richer data, such as user info or system metadata.
