Sentiment analysis of product reviews using Google Sheets & OpenAI
Created by: WeblineIndia || weblineindia
WeblineIndia
Last update a month ago
🧠 Sentiment Analysis of Product Reviews using Google Sheets & OpenAI
🚀 Quick Implementation Steps
Automated customer feedback analyzer:
  • Trigger: Google Sheets triggers on new product review rows.
  • Sentiment Analysis: Review text sent to OpenAI.
  • Writeback: Resulting sentiment (Positive, Neutral, Negative) is written back to the sheet.
Just connect your credentials and sheet — you're ready to go!
🔍 What It Does
This workflow automatically analyzes user-submitted product reviews and classifies them by sentiment using OpenAI’s powerful language models. It eliminates the need to manually sift through feedback by tagging each review with a sentiment score.
The sentiment result is then written back to the Google Sheet next to the original review, enabling you to get a fast, clear snapshot of overall customer perception, satisfaction and pain points. Whether you're monitoring 10 or 10,000 reviews, this process scales effortlessly and updates every minute.
👤 Who’s It For
This workflow is designed for:
  • E-commerce teams collecting user reviews.
  • Product teams monitoring customer feedback.
  • Marketing teams identifying promotable reviews.
  • Support teams watching for negative experiences.
  • SaaS platforms, apps, and survey tools managing structured text feedback.
✅ Requirements
You’ll need:
  • A Google Sheet with two columns: Review and Sentiment
  • Google Sheets OAuth2 credentials in n8n
  • OpenAI API Key (for GPT-4o-mini or GPT-3.5)
  • n8n instance with LangChain and OpenAI nodes enabled
⚙️ How It Works
  1. Google Sheets Trigger: Watches for new rows every minute
  2. OpenAI Integration:
    • Uses LangChain’s Sentiment Analysis node
    • Passes review text into GPT-4o-mini via the OpenAI Chat Model node
  3. Sheet Update: The sentiment result (Positive, Negative, or Neutral) is written into the Sentiment column in the same row.
Sticky Notes included for better visual understanding inside the workflow editor.
🛠️ Steps to Configure and Use
1. Prepare Your Google Sheet
Make sure your sheet is named Sheet1 with the following structure:
Review Sentiment
Absolutely love it!
Not worth the price.
2. Set Up Credentials
  • Google Sheets: OAuth2 credentials
  • OpenAI: API Key added via OpenAI API credential in n8n
3. Import & Activate Workflow
  • Import the workflow JSON into your n8n instance.
  • Assign the proper credentials to the trigger and OpenAI nodes.
  • Activate the workflow.
🧩 How To Customize
  • 🛎️ Alerting: Add Slack/Email nodes for negative sentiment alerts
  • 🔄 Triggering: Change the polling interval to real-time triggers (e.g., webhook)
  • 📊 Extended Sentiment: Modify sentiment categories (e.g., "Mixed", "Sarcastic")
  • 🧾 Summary Report: Add Cron + Aggregation nodes for daily/weekly summaries
  • 🧠 Prompt Tuning: Adjust system prompt for deeper or context-based sentiment evaluation
🧱 Add‑ons (Optional Features)
  • Email Digest of Negative Reviews
  • Google Drive Logging
  • Team Notification via Slack
  • Summary to Notion, Airtable, or Google Docs
📌 Use Case Examples
  • Online Stores: Auto-tag reviews for reputation monitoring
  • Product Teams: See which feature releases generate positive or negative buzz
  • CX Dashboards: Feed real-time sentiment to internal BI tools
  • Marketing: Extract glowing reviews for social proof
  • Support: Triage issues by flagging critical comments instantly
...and many more applications wherever text feedback is collected.
🧰 Troubleshooting Guide
Issue Possible Cause Suggested Fix
Sentiment not updating Sheet credentials missing or misconfigured Reconnect Google Sheets OAuth2
Blank sentiment Review column empty or misaligned Ensure proper column header & value present
OpenAI errors Invalid or expired API key Regenerate API Key from OpenAI and re-auth
Workflow doesn’t run Polling settings incorrect Confirm interval & document ID in trigger node
🤝 Need Help?
If you need assistance for
  • ✅ Help setting up this workflow
  • ⚙️ Customizing prompts or output
  • 🚀 Automating your full review pipeline
👉 Contact us today at WeblineIndia. We will be happy to assist.
