Auto-like LinkedIn posts with GPT-4o, Phantombuster and SharePoint
Created by: plemeo || plemeo
plemeo
Last update 15 days ago
Who’s it for
Recruiters, B2B marketers, and thought-leadership builders who want to boost their LinkedIn engagement by automatically liking fresh, relevant posts—while staying under LinkedIn’s daily limits.
How it works / What it does
  1. Schedule Trigger runs hourly at a specified minute.
  2. Select Cookie chooses a rotating LinkedIn session-cookie (time-slice logic).
  3. Generate Random Search Term (GPT-4o) outputs a realistic AI/BPA keyword.
  4. Phantombuster LinkedIn Content Search Agent scrapes recent posts → Get Posts.
  5. Get Random Post selects one post, checks it isn’t already liked (SharePoint CSV) and appends the company-ID query param. If a personal LinkedIn Account is used, no company-ID is needed.
  6. Creates linkedin_posts_to_like.csv, uploads to SharePoint, and provides the URL to Autolike Agent which likes the post.
  7. The post URL is added to linkedin_posts_already_liked.csv to avoid duplicates.
  8. Wait nodes throttle launches to ≈400 likes/day.
How to set up
  1. Add credentials: Phantombuster API, SharePoint OAuth2, OpenAI API key.
  2. In SharePoint › “Phantombuster” folder create:
    linkedin_session_cookies.txt – one cookie per line.
    linkedin_posts_already_liked.csv with header postUrl.
  3. Update Set ENV Variables with your LinkedIn company ID (ENV_COMPANY_ID_LINKEDIN).
  4. Adjust schedule or likes-per-launch as needed.
  5. Activate the workflow; it will run hourly and like one new post per launch.
Requirements
  • n8n 1.33 +
  • Phantombuster Growth plan (API access)
  • OpenAI account (GPT-4o)
  • Microsoft 365 SharePoint tenant
How to customize
  • Change niche: edit the prompt in Generate Random Search Term.
  • Like more posts: raise numberOfLinesPerLaunch and schedule frequency.
  • Swap SharePoint for Google Drive/Dropbox: replace the upload/download nodes.
