Automatic LinkedIn engagement with AI comments using GPT-4o and Phantombuster
Created by: plemeo || plemeo
plemeo
Last update 15 days ago
Who’s it for
B2B marketers, recruiters, and personal-brand builders who want to spark
conversations on LinkedIn by automatically posting short, relevant comments on
fresh industry content—while staying under daily limits.
How it works / What it does
  1. Schedule Trigger fires every hour.
  2. Select Cookie picks a rotating LinkedIn session-cookie (time-slice logic).
  3. Generate Random Search Term (GPT-4o) outputs a realistic AI/BPA keyword.
  4. LinkedIn Search Agent (Phantombuster) scrapes recent posts.
  5. Get Random Post chooses one post and passes its text to Create Comment
    (GPT-4o) which returns a ≤150-character reply in the chosen language.
  6. Builds linkedin_posts_to_comment.csv, uploads to SharePoint, and launches
    the Auto-comment Agent to post the reply.
  7. Post URL is logged to linkedin_posts_already_commented.csv to avoid
    duplicates.
  8. Wait nodes throttle launches to ~120 comments/day.
How to set up
  1. Add credentials: Phantombuster API, SharePoint OAuth2, OpenAI API key.
  2. In SharePoint › “Phantombuster” folder create:
    linkedin_session_cookies.txt – one cookie per line.
    linkedin_posts_already_commented.csv with header postUrl.
  3. Edit Set ENV Variables to set default language, comment prompt,
    company ID, etc.
  4. Adjust schedule or comments-per-launch as needed.
  5. Activate the workflow; it will run hourly and comment on one new post each
    launch.
Requirements
  • n8n 1.33 +
  • Phantombuster Growth plan (API access)
  • OpenAI account
  • Microsoft 365 SharePoint tenant
How to customize
  • Change tone/length: edit the prompt in Create Comment.
  • Comment more often: raise numberOfLinesPerLaunch and schedule frequency.
  • Use Google Drive/Dropbox instead of SharePoint by swapping storage nodes.
