Scheduled Instagram auto-liker with Phantombuster, GPT-4o & cookie rotation
Created by: plemeo || plemeo
plemeo
Last update 22 days ago
Who’s it for
Social-media managers and brands that want to keep their Instagram
accounts active by automatically liking fresh posts under selected
hashtags—hands-free and rate-limited.
How it works / What it does
  1. Schedule Trigger runs every 2 hours at a specified minute.
  2. Select Cookie chooses a rotating Instagram session-cookie
    (time-slice logic).
  3. Generate Random Hashtag (GPT-4o) outputs a realistic AI/BPA
    hashtag.
  4. Instagram Hashtag Agent (Phantombuster) scrapes up to
    ENV_MAX_POSTS_PER_HASHTAG recent posts.
  5. Get Random Post selects one; duplicate checker ensures it
    hasn’t been liked before (SharePoint CSV).
  6. Builds instagram_posts_to_like.csv, uploads to SharePoint, then
    launches the Auto-like Agent which likes the post.
  7. Post URL is appended to instagram_posts_already_liked.csv to avoid
    duplicates.
  8. Wait nodes throttle launches to ~12 likes per profile daily.
How to set up
  1. Add credentials: Phantombuster API, SharePoint OAuth2, OpenAI API
    key.
  2. In SharePoint › “Phantombuster” folder create:
    instagram_session_cookies.txt – one cookie per line.
    instagram_posts_already_liked.csv with header postUrl.
  3. Adjust Set ENV Variables to change max posts per scrape.
  4. Activate the workflow; it will like one post every 2 hours.
Requirements
  • n8n 1.33 +
  • Phantombuster Growth plan (API access)
  • OpenAI account
  • Microsoft 365 SharePoint tenant
How to customize
  • Target a different niche: edit hashtag prompt in Generate Random Hashtag.
  • Like more posts: raise ENV_MAX_POSTS_PER_HASHTAG,
    numberOfPostsPerLaunch, or schedule frequency.
  • Replace SharePoint with Drive/Dropbox by swapping storage nodes.
