Auto-comment on Instagram posts with GPT-4o, Phantombuster, and SharePoint
Created by: plemeo || plemeo
plemeo
Last update a month ago
Who’s it for
Social-media teams and influencers who want to grow engagement by
automatically posting short, relevant comments on new Instagram posts
under rotating hashtags—while staying under platform limits.
How it works / What it does
  1. Schedule Trigger fires every 2 h at a specified minute.
  2. Select Cookie chooses a rotating Instagram session-cookie by
    time slice.
  3. Generate Random Hashtag (GPT-4o) outputs a realistic AI/BPA tag.
  4. Hashtag Agent (Phantombuster) scrapes up to
    ENV_MAX_POSTS_PER_HASHTAG recent posts.
  5. Get Random Post picks one; Create Comment (GPT-4o) crafts a
    ≤150-character reply in the chosen language.
  6. Builds instagram_post_to_comment.csv, uploads to SharePoint, then
    launches the Auto-comment Agent which posts the reply.
  7. Post URL is logged to instagram_posts_already_commented.csv
    to avoid duplicates.
  8. Wait nodes throttle launches to ≈80 comments/day.
How to set up
  1. Add credentials: Phantombuster API, SharePoint OAuth2, OpenAI API key.
  2. In SharePoint › “Phantombuster” folder create:
    instagram_session_cookies.txt – one cookie per line.
    instagram_posts_already_commented.csv with header postUrl.
  3. Edit Set ENV Variables to set default language, prompt, and max
    posts per scrape.
  4. Activate the workflow; it will comment every 2 h.
Requirements
  • n8n 1.33 +
  • Phantombuster Growth plan (API access)
  • OpenAI account (GPT-4o)
  • Microsoft 365 SharePoint tenant
How to customize
  • Change tone/length: tweak prompt in Create Comment.
  • Comment more often: raise ENV_MAX_POSTS_PER_HASHTAG,
    adjust cron, and agent limits.
  • Swap SharePoint for Drive/Dropbox by replacing storage nodes.
