Generate & Process Audio with Voxtral Small 24B AI using Replicate API
Yaron Been
Last update 2 days ago
This workflow provides automated access to the Notdaniel Voxtral Small 24B 2507 AI model through the Replicate API. It saves you time by eliminating the need to manually interact with AI models and provides a seamless integration for audio generation tasks within your n8n automation workflows.
Overview
This workflow automatically handles the complete audio generation process using the Notdaniel Voxtral Small 24B 2507 model. It manages API authentication, parameter configuration, request processing, and result retrieval with built-in error handling and retry logic for reliable automation.
Model Description: Voxtral Small is an enhancement of Mistral Small 3 that incorporates state-of-the-art audio input capabilities and excels at speech transcription, translation and audio understanding.
Key Capabilities
  • AI-driven audio generation and processing
  • High-quality sound synthesis
  • Advanced audio manipulation tools
Tools Used
  • n8n: The automation platform that orchestrates the workflow
  • Replicate API: Access to the Notdaniel/voxtral-small-24b-2507 AI model
  • Notdaniel Voxtral Small 24B 2507: The core AI model for audio generation
  • Built-in Error Handling: Automatic retry logic and comprehensive error management
How to Install
  1. Import the Workflow: Download the .json file and import it into your n8n instance
  2. Configure Replicate API: Add your Replicate API token to the 'Set API Token' node
  3. Customize Parameters: Adjust the model parameters in the 'Set Audio Parameters' node
  4. Test the Workflow: Run the workflow with your desired inputs
  5. Integrate: Connect this workflow to your existing automation pipelines
Use Cases
  • Music Production: Generate background music and audio tracks
  • Podcast Enhancement: Create intro/outro music and sound effects
  • Audio Content: Produce voiceovers and audio narration
  • Sound Design: Generate custom audio for games and applications
Connect with Me
#n8n #automation #ai #replicate #aiautomation #workflow #nocode #audiogeneration #aiaudio #soundgeneration #musicai #audioautomation #machinelearning #artificialintelligence #aitools #automation #digitalart #contentcreation #productivity #innovation
