Generate High-Quality Images with Replicate's Fire/Flux AI Model
Yaron Been
Last update 2 days ago
Fire Flux Image Generator
Description
The image generation model tailored for local development and personal use
Overview
This n8n workflow integrates with the Replicate API to use the fire/flux model. This powerful AI model can generate high-quality image content based on your inputs.
Features
  • Easy integration with Replicate API
  • Automated status checking and result retrieval
  • Support for all model parameters
  • Error handling and retry logic
  • Clean output formatting
Parameters
Required Parameters
  • prompt (string): Prompt for generated image
Optional Parameters
  • seed (integer, default: 0): Random seed. Set for reproducible generation
  • go_fast (boolean, default: True): Run faster predictions with model optimized for speed (currently fp8 quantized); disable to run in original bf16
  • megapixels (string, default: 1): Approximate number of megapixels for generated image
  • num_outputs (integer, default: 1): Number of outputs to generate
  • aspect_ratio (string, default: 2:1): Aspect ratio for the generated image
  • output_format (string, default: png): Format of the output images
  • output_quality (integer, default: 80): Quality when saving the output images, from 0 to 100. 100 is best quality, 0 is lowest quality. Not relevant for .png outputs
  • num_inference_steps (integer, default: 4): Number of denoising steps. 4 is recommended, and lower number of steps produce lower quality outputs, faster.
  • disable_safety_checker (boolean, default: False): Disable safety checker for generated images.
How to Use
  1. Set up your Replicate API key in the workflow
  2. Configure the required parameters for your use case
  3. Run the workflow to generate image content
  4. Access the generated output from the final node
API Reference
Requirements
  • Replicate API key
  • n8n instance
  • Basic understanding of image generation parameters
