Blockchain monitor with ScrapeGraphAI risk detection, instant alerts and Slack
Created by: vinci-king-01 || vinci-king-01
vinci-king-01
Last update 24 days ago
Smart Blockchain Monitor with ScrapeGraphAI Risk Detection and Instant Alerts
🎯 Target Audience
  • Cryptocurrency traders and investors
  • DeFi protocol managers and developers
  • Blockchain security analysts
  • Financial compliance officers
  • Crypto fund managers and institutions
  • Risk management teams
  • Blockchain developers monitoring smart contracts
  • Digital asset custodians
🚀 Problem Statement
Manual blockchain monitoring is time-consuming and prone to missing critical events, often leading to delayed responses to high-value transactions, security threats, or unusual network activity. This template solves the challenge of real-time blockchain surveillance by automatically detecting, analyzing, and alerting on significant blockchain events using AI-powered intelligence and instant notifications.
🔧 How it Works
This workflow automatically monitors blockchain activity in real-time, uses ScrapeGraphAI to intelligently extract transaction data from explorer pages, performs sophisticated risk analysis, and instantly alerts your team about significant events across multiple blockchains.
Key Components
  1. Blockchain Webhook - Real-time trigger that activates when new blocks are detected
  2. Data Normalizer - Standardizes blockchain data across different networks
  3. ScrapeGraphAI Extractor - AI-powered transaction data extraction from blockchain explorers
  4. Risk Analyzer - Advanced risk scoring based on transaction patterns and values
  5. Smart Filter - Intelligently routes only significant events for alerts
  6. Slack Alert System - Instant formatted notifications to your team
📊 Risk Analysis Specifications
The template performs comprehensive risk analysis with the following parameters:
Risk Factor Threshold Score Impact Description
High-Value Transactions >$10,000 USD +15 per transaction Individual transactions exceeding threshold
Block Volume >$1M USD +20 points Total block transaction volume
Block Volume >$100K USD +10 points Moderate block transaction volume
Failure Rate >10% +15 points Percentage of failed transactions in block
Multiple High-Value >3 transactions Alert trigger Multiple large transactions in single block
Critical Failure Rate >20% Alert trigger Extremely high failure rate indicator
Risk Levels:
  • High Risk: Score ≥ 50 (Immediate alerts)
  • Medium Risk: Score ≥ 25 (Standard alerts)
  • Low Risk: Score < 25 (No alerts)
🌐 Supported Blockchains
Blockchain Explorer Native Support Transaction Detection
Ethereum Etherscan ✅ Full High-value, DeFi, NFT
Bitcoin Blockchair ✅ Full Large transfers, institutional
Binance Smart Chain BscScan ✅ Full DeFi, high-frequency trading
Polygon PolygonScan ✅ Full Layer 2 activity monitoring
🛠️ Setup Instructions
Estimated setup time: 15-20 minutes
Prerequisites
  • n8n instance with community nodes enabled
  • ScrapeGraphAI API account and credentials
  • Slack workspace with webhook or bot token
  • Blockchain data source (Moralis, Alchemy, or direct node access)
  • Basic understanding of blockchain explorers
Step-by-Step Configuration
1. Install Community Nodes
# Install required community nodes
npm install n8n-nodes-scrapegraphai
2. Configure ScrapeGraphAI Credentials
  • Navigate to Credentials in your n8n instance
  • Add new ScrapeGraphAI API credentials
  • Enter your API key from ScrapeGraphAI dashboard
  • Test the connection to ensure proper functionality
3. Set up Slack Integration
  • Add Slack OAuth2 or webhook credentials
  • Configure your target channel for blockchain alerts
  • Test message delivery to ensure notifications work
  • Customize alert formatting preferences
4. Configure Blockchain Webhook
  • Set up the webhook endpoint for blockchain data
  • Configure your blockchain data provider (Moralis, Alchemy, etc.)
  • Ensure webhook payload includes block number and blockchain identifier
  • Test webhook connectivity with sample data
5. Customize Risk Parameters
  • Adjust high-value transaction threshold (default: $10,000)
  • Modify risk scoring weights based on your needs
  • Configure blockchain-specific risk factors
  • Set failure rate thresholds for your use case
6. Test and Validate
  • Send test blockchain data to trigger the workflow
  • Verify ScrapeGraphAI extraction accuracy
  • Check risk scoring calculations
  • Confirm Slack alerts are properly formatted and delivered
🔄 Workflow Customization Options
Modify Risk Analysis
  • Adjust high-value transaction thresholds per blockchain
  • Add custom risk factors (contract interactions, specific addresses)
  • Implement whitelist/blacklist address filtering
  • Configure time-based risk adjustments
Extend Blockchain Support
  • Add support for additional blockchains (Solana, Cardano, etc.)
  • Customize explorer URL patterns
  • Implement chain-specific transaction analysis
  • Add specialized DeFi protocol monitoring
Enhance Alert System
  • Add email notifications alongside Slack
  • Implement severity-based alert routing
  • Create custom alert templates
  • Add alert escalation rules
Advanced Analytics
  • Add transaction pattern recognition
  • Implement anomaly detection algorithms
  • Create blockchain activity dashboards
  • Add historical trend analysis
📈 Use Cases
  • Crypto Trading: Monitor large market movements and whale activity
  • DeFi Security: Track protocol interactions and unusual contract activity
  • Compliance Monitoring: Detect suspicious transaction patterns
  • Institutional Custody: Alert on high-value transfers and security events
  • Smart Contract Monitoring: Track contract interactions and state changes
  • Market Intelligence: Analyze blockchain activity for trading insights
🚨 Important Notes
  • Respect ScrapeGraphAI API rate limits and terms of service
  • Implement appropriate delays to avoid overwhelming blockchain explorers
  • Keep your API credentials secure and rotate them regularly
  • Monitor API usage to manage costs effectively
  • Consider blockchain explorer rate limits for high-frequency monitoring
  • Ensure compliance with relevant financial regulations
  • Regularly update risk parameters based on market conditions
🔧 Troubleshooting
Common Issues:
  • ScrapeGraphAI extraction errors: Check API key and account status
  • Webhook trigger failures: Verify webhook URL and payload format
  • Slack notification failures: Check bot permissions and channel access
  • False positive alerts: Adjust risk scoring thresholds
  • Missing transaction data: Verify blockchain explorer accessibility
  • Rate limit errors: Implement delays and monitor API usage
Support Resources:
  • ScrapeGraphAI documentation and API reference
  • n8n community forums for workflow assistance
  • Blockchain explorer API documentation
  • Slack API documentation for advanced configurations
  • Cryptocurrency compliance and regulatory guidelines
