Track food calories via Telegram with GPT-4 Vision and Google Sheets
Created by: Shiva || shivp1413
Shiva
Last update 17 days ago
This workflow enables users to submit food images to a Telegram bot, which uses OpenAI’s GPT-4 Vision to identify the item and estimate its caloric value. The results are stored in Google Sheets and sent back to the user.
What it does:
  1. Triggers on a photo sent via Telegram.
  2. Acknowledges the user with a sticky note message.
  3. Downloads the image file securely using Telegram's API.
  4. Sends the image to GPT-4 Vision with a prompt: “Describe this food and estimate its calories.”
  5. Logs the GPT response to a Google Sheet (with timestamp).
  6. Replies to the user with the result (e.g., food name and estimated calories).
Use cases:
  • Personal food tracking
  • Nutrition logging via chat
  • Meal journaling for fitness or health
Requirements:
  • Telegram Bot Token (via credentials)
  • OpenAI GPT-4 Vision access
  • Google Sheets credential with access to the target sheet
Notes:
  • You can extend this template to calculate daily totals, categorize meals (breakfast/lunch/dinner), or even integrate with calorie goals.
  • The sticky note node confirms receipt to enhance UX.
  • Ideal for wellness apps, chat-based food journals, or AI-powered health bots.
