Automate tweet filtering and replies on X with GPT and scheduled rotation
Created by: Jorge Martínez || jorgemartinezjam
Jorge Martínez
Last update 20 days ago
Automate tweet engagement on X (formerly Twitter)
Description
Automate professional engagement on X (formerly Twitter) by searching for, filtering, liking, and replying to tweets that match your key topics. This workflow enables you to engage consistently and efficiently with relevant conversations, using your defined professional role and the power of GPT for filtering and replies. Save time and maintain high-quality interactions, while staying focused on your business or personal brand interests.
How it Works
  1. Rotating Topic Selection
    The workflow selects one search term from your list on each run, using a rotating index based on the date.
  2. Search Tweets & Extract Essentials
    Searches X (formerly Twitter) for tweets matching the chosen topic, then extracts only the tweet id and text for further processing.
  3. GPT‑Based Filtering with Role Context
    Filters tweets based on your role and strict criteria, removing non-English tweets, memes, spam, Grok-generated content, political posts, internships, and more.
  4. Engagement Loop
    For every filtered tweet, the workflow likes the post, generates a professional, concise reply with GPT (matching language and context), and posts the reply. Wait nodes ensure compliance with Twitter’s API rate limits (can be adjusted for paid API tiers).
Requirements
  • X (Twitter) API credentials (for searching, liking, and replying to tweets)
  • OpenAI API key (for GPT-based steps)
Setup Steps
  1. Obtain your X (Twitter) API credentials.
  2. Obtain your OpenAI API key.
  3. Configure the schedule in the trigger node to your desired frequency (e.g., every 3 days or daily).
  4. Set your list of topics and professional role in the variables node.
How to Customize the Workflow (Optional)
  • Adjust prompts in the GPT nodes to fine-tune filtering and reply style.
  • Upgrade your Twitter API plan to increase request limits and search for more tweets per run.
  • Change tweet processing logic: For high-volume engagement (e.g., analyzing 100+ tweets per run), consider switching to a per-tweet loop for advanced filtering and response handling.
This workflow enables scalable, professional, and targeted engagement on X (formerly Twitter), fully customizable to your audience and objectives.
