Paigedutcher2 Paige AI Generator
Description
"Custom AI model trained on Paige — bold, curvy, confident energy. Think Barbie meets boss. Great for glam, fantasy, seductive, and influencer-style prompts. Use trigger word CharacterPGE to activate the model.
Overview
This n8n workflow integrates with the Replicate API to use the paigedutcher2/paige model. This powerful AI model can generate high-quality other content based on your inputs.
Features
- Easy integration with Replicate API
- Automated status checking and result retrieval
- Support for all model parameters
- Error handling and retry logic
- Clean output formatting
Parameters
Required Parameters
- prompt (string): Prompt for generated image. If you include the
trigger_word
used in the training process you are more likely to activate the trained object, style, or concept in the resulting image.
Optional Parameters
- mask (string, default: None): Image mask for image inpainting mode. If provided, aspect_ratio, width, and height inputs are ignored.
- seed (integer, default: None): Random seed. Set for reproducible generation
- image (string, default: None): Input image for image to image or inpainting mode. If provided, aspect_ratio, width, and height inputs are ignored.
- model (string, default: dev): Which model to run inference with. The dev model performs best with around 28 inference steps but the schnell model only needs 4 steps.
- width (integer, default: None): Width of generated image. Only works if
aspect_ratio
is set to custom. Will be rounded to nearest multiple of 16. Incompatible with fast generation
- height (integer, default: None): Height of generated image. Only works if
aspect_ratio
- go_fast (boolean, default: False): Run faster predictions with model optimized for speed (currently fp8 quantized); disable to run in original bf16
- extra_lora (string, default: None): Load LoRA weights. Supports Replicate models in the format <owner>/<username> or <owner>/<username>/<version>, HuggingFace URLs in the format huggingface.co/<owner>/<model-name>, CivitAI URLs in the format civitai.com/models/<id>[/<model-name>], or arbitrary .safetensors URLs from the Internet. For example, 'fofr/flux-pixar-cars'
- lora_scale (number, default: 1): Determines how strongly the main LoRA should be applied. Sane results between 0 and 1 for base inference. For go_fast we apply a 1.5x multiplier to this value; we've generally seen good performance when scaling the base value by that amount. You may still need to experiment to find the best value for your particular lora.
- megapixels (string, default: 1): Approximate number of megapixels for generated image
How to Use
- Set up your Replicate API key in the workflow
- Configure the required parameters for your use case
- Run the workflow to generate other content
- Access the generated output from the final node
API Reference
Requirements
- Replicate API key
- n8n instance
- Basic understanding of other generation parameters
