An experiment: a fine-tuned FLUX model for UI design generation
This n8n workflow integrates with the Replicate API to use the justingirard/draft-ui-designer model. This powerful AI model can generate high-quality image content based on your inputs.
trigger_word
used in the training process you are more likely to activate the trained object, style, or concept in the resulting image.aspect_ratio
is set to custom. Will be rounded to nearest multiple of 16. Incompatible with fast generationaspect_ratio
