None
This n8n workflow integrates with the Replicate API to use the settyan/flash-v2.0.0-beta.0 model. This powerful AI model can generate high-quality other content based on your inputs.
trigger_word
used in the training process you are more likely to activate the trained object, style, or concept in the resulting image.aspect_ratio
is set to custom. Will be rounded to nearest multiple of 16. Incompatible with fast generationaspect_ratio
