Generate AI Text Control Vectors with Replicate's Ilearnmate-ICTS Model
Yaron Been
Last update a day ago
Spuuntries Ilearnmate Icts AI Generator
Description
None
Overview
This n8n workflow integrates with the Replicate API to use the spuuntries/ilearnmate-icts model. This powerful AI model can generate high-quality other content based on your inputs.
Features
  • Easy integration with Replicate API
  • Automated status checking and result retrieval
  • Support for all model parameters
  • Error handling and retry logic
  • Clean output formatting
Parameters
Optional Parameters
  • seed (integer, default: None): Seed for reproducibility of example generation and vector training. Set to 0 for random behavior.
  • num_examples_per_side (integer, default: 3): Number of descriptive examples to generate for each side of the contrast. More examples might lead to better vectors but will increase generation time.
  • attributes_to_generate (string, default: girly,modestly,verbose,happy): Comma-separated list of attributes for which to generate control vectors (e.g., 'girly,modestly,verbose,happy')
How to Use
  1. Set up your Replicate API key in the workflow
  2. Configure the required parameters for your use case
  3. Run the workflow to generate other content
  4. Access the generated output from the final node
API Reference
Requirements
  • Replicate API key
  • n8n instance
  • Basic understanding of other generation parameters
