This workflow is perfect for individuals, small businesses, or households who need to:
This comprehensive expense processing workflow combines AI-powered document analysis with automated file management and notifications. Here's the complete flow:
Form Submission: Users submit expenses through a web form with receipt upload and category selection (Personal, Business, or Shared/Home)
AI Document Processing: The workflow extracts text from PDF receipts using OCR, then uses Google Gemini AI to parse and structure the data into a standardized JSON format including vendor details, amounts, dates, and categorization
Smart Routing: Based on the expense category, receipts are automatically routed to different processing paths with category-specific folder organization
Multi-Destination Storage: Receipts are uploaded to:
Email Notifications: Sends formatted HTML email notifications with complete expense details and links to stored receipts
Accounting System Integration: Automatically forwards business expenses to accounting systems via email hooks (customizable per user requirements)
Replace all placeholder values:
YOUR_GEMINI_CREDENTIAL_ID
with your Gemini credential IDYOUR_PERSONAL_GDRIVE_CREDENTIAL_ID
with personal Drive credentialYOUR_BUSINESS_GDRIVE_CREDENTIAL_ID
with business Drive credentialYOUR_GMAIL_CREDENTIAL_ID
with Gmail credentialYOUR_S3_CREDENTIAL_ID
with S3 credentialUpdate Google Drive folder structure:
YOUR_BUSINESS_DRIVE_ID
and YOUR_SHARED_DRIVE_ID
with actual drive IDsConfigure email addresses:
[email protected]
with your notification email[email protected]
with your accounting system's email hook (this is a mail hook for uploading documents to small business accounting systems - can be modified per user requirements)Update S3 bucket names:
business-expenses
, personal-expenses
, and shared-expenses
with your bucket namesCreate organized folder structures in your Google Drives:
Drive Root/
├── 2024/
│ ├── January/
│ ├── February/
│ └── ... (all months)
├── 2025/
│ ├── January/
└── 2026/
Modify the form dropdown options and conditional logic to add/remove expense categories:
Customize the structured output parser schema to extract different fields:
Add or modify storage locations:
Customize the HTML email template:
Update the JavaScript code in Code nodes to match your folder structure:
Extend the workflow with additional integrations:
