Monitor blood bank stock & send low level alerts with Google Sheets and WhatsApp
Last update 24 days ago
Categories
This n8n workflow monitors blood stock levels daily and sends alerts when availability is low. It fetches data from a Google Sheet, checks stock status, and notifies via WhatsApp.
Key Features
  • Daily Monitoring: Checks blood stock every day.
  • Automated Alerts: Sends notifications when stock is low.
  • Real-Time Updates: Uses live data from Google Sheets.
  • Efficient Delivery: Alerts sent instantly via WhatsApp.
  • Continuous Check: Loops to ensure ongoing monitoring.
Workflow Process
  1. Daily Check Blood Stock: Triggers the workflow daily.
  2. Fetch Blood Stock: Reads data from a Google Sheet.
  3. Get All Stock: Collects all available blood stock details.
  4. Check Stock Availability: Analyzes stock levels for low thresholds.
  5. Send Alert Message: Sends WhatsApp alerts if stock is low.
Sheet Columns
  • Blood Type: Type of blood (e.g., A+, O-).
  • Quantity: Current stock amount.
  • Threshold: Minimum acceptable stock level.
  • Last Updated: Date and time of last update.
  • Status: Current status (e.g., Low, Sufficient).
Setup Instructions
  • Import Workflow: Add the workflow to n8n via the import option.
  • Configure Sheet: Set up a Google Sheet with blood stock data.
  • Set Up WhatsApp: Configure WhatsApp API credentials in n8n.
  • Activate: Save and enable the workflow.
  • Test: Simulate low stock to verify alerts.
Requirements
  • n8n Instance: Hosted or cloud-based n8n setup.
  • Google Sheets: Access with stock data.
  • WhatsApp API: Integration for sending alerts.
  • Admin Access: For monitoring and updates.
Customization Options
  • Adjust Threshold: Change low stock limits.
  • Add Channels: Include email or SMS alerts.
  • Update Frequency: Modify daily trigger time.
