AI-powered HighLevel CRM automation with GPT and MCP for contact and task management
Created by: Paul || diagopl
Paul
Last update a month ago
Categories
HighLevel MCP Full CRM Automation
With the HighLevel MCP Automation Workflow, you unlock the full potential of AI-driven CRM management inside n8n.
This setup turns your HighLevel account into a fully orchestrated MCP-powered system, capable of executing contact management, opportunity tracking, task handling, and calendar scheduling automatically — all from a single intelligent trigger.
Every action is performed through the MCP layer, ensuring seamless integration, instant execution, and real-time synchronization without manual effort.
Whether you need to create a contact, update an opportunity, fetch available appointment slots, or close a task, the MCP workflow manages it end-to-end with precision.
This is more than an automation — it’s a dedicated MCP agent for HighLevel that runs 24/7, keeping your CRM up-to-date, your pipeline organized, and your operations moving without delays.
Harness the MCP framework to eliminate repetitive CRM work and maintain a perfectly optimized sales and operations flow.
