Auto-post WordPress articles to social media with Gemini AI & Blotato
Created by: David Olusola || dae221
David Olusola
Last update a month ago
This workflow contains community nodes that are only compatible with the self-hosted version of n8n.
WordPress to Blotato Social Publisher
Overview:
This automation monitors your WordPress site for new posts and automatically creates platform-specific social media content using AI, then posts to Twitter, LinkedIn, and Facebook via Blotato.
What it does:
  • Monitors WordPress site for new posts every 30 minutes
  • Filters posts published in the last hour to avoid duplicates
  • Processes each new post individually
  • AI generates optimized content for each social platform (Twitter, LinkedIn, Facebook)
  • Extracts platform-specific content from AI response
  • Publishes to all three social media platforms via Blotato API
Setup Required:
  1. WordPress Connection
    • Configure WordPress credentials in the "Check New Posts" node
    • Enter your WordPress site URL, username, and password/app password
  2. Blotato Social Media API Setup
    • Get your Blotato API key from your Blotato account
    • Configure API credentials in the Blotato connection node
    • Map each platform (Twitter, LinkedIn, Facebook) to the correct Blotato channel
  3. AI Configuration
    • Set up Google Gemini API credentials
    • Connect the Gemini model to the "AI Social Content Creator" node
  4. Customization Options
    • Posting Frequency: Modify schedule trigger (default: every 30 minutes)
    • Content Tone: Adjust AI system message for different writing styles
    • Post Filtering: Change time window in WordPress node (default: last hour)
    • Platform Selection: Remove any social media platforms you don’t want to use
  5. Testing
    • Run workflow manually to test connections
    • Verify posts appear correctly on all platforms
    • Monitor for API rate limit issues
Features:
  • Platform-optimized content (hashtags, character limits, professional tone)
  • Duplicate prevention system
  • Batch processing for multiple posts
  • Featured image support
  • Customizable posting frequency
Customization:
  • Change monitoring frequency
  • Adjust AI prompts for different tones
  • Add/remove social platforms
  • Modify hashtag strategies
Need Help?
For n8n coaching or one-on-one consultation
