Create a Witty Telegram Bot with AI-Powered Humor, Roasts & Stats using OpenRouter
Last update 24 days ago
GiggleGPTBot — Witty Telegram Bot with AI & Postgres
📝 Overview
GiggleGPTBot is a witty Telegram bot built with n8n, OpenRouter, and Postgres.
It delivers short jokes, motivational one-liners, and playful roasts, responds to mentions, and posts scheduled witty content.
The workflow also tracks user activity and provides lightweight statistics and leaderboards.
✨ Features
  • 🤖 AI-powered humor engine — replies with jokes, motivation, random witty lines, or sarcastic roasts.
  • 💬 Command support/joke, /inspire, /random, /roast, /help, /stats, /top.
  • 🎯 Mention detection — replies when users tag @GiggleGPTBot.
  • Scheduled posts — morning jokes, daily motivation, and random wisdom at configured times.
  • 📊 User analytics — counts messages, commands, reactions, and generates leaderboards.
  • 🗄️ Postgres persistence — robust schema with tables for messages, responses, stats, and schedules.
🛠️ How It Works
  1. Triggers
    • Telegram Trigger — receives all messages and commands from a chat.
    • Schedule Trigger — runs hourly to check for planned posts.
  2. Processing
    • Switch routes commands (/joke, /inspire, /random, /roast, /help, /stats, /top).
    • Chat history fetches the latest context.
    • Mention Analysis determines if the bot was mentioned.
    • Generating an information response builds replies for /help, /stats, /top.
    • AI nodes (AI response to command, AI response to mention, AI post generation) craft witty content via OpenRouter.
  3. Persistence
    • Init Database ensures tables exist (user_messages, bot_responses, bot_commands, message_reactions, scheduled_posts, user_stats).
    • Logging nodes update stats and store every bot/user interaction.
  4. Delivery
    • Replies are sent back via Telegram Send nodes (Send AI response, Send info reply, Reply to Mention, Submit scheduled post).
⚙️ Setup Instructions
  1. Create a Telegram Bot with @BotFather and get your API token.
  2. Add credentials in n8n:
    • Telegram API (your bot token)
    • OpenRouter (API key from openrouter.ai)
    • Postgres (use your DB, Supabase works well).
  3. Run the Init Database node once to create all required tables.
  4. (Optional) Seed schedule with the Adding a schedule node — it inserts:
    • Morning joke at 06:00
    • Daily motivation at 09:00
    • Random wisdom at 17:00
      (Adjust chat_id to your group/channel ID.)
  5. Activate workflow and connect Telegram Webhook or Polling.
📊 Database Schema
  • user_messages — stores user chat messages.
  • bot_responses — saves bot replies.
  • bot_commands — logs command usage.
  • message_reactions — tracks reactions.
  • scheduled_posts — holds scheduled jokes/wisdom/motivation.
  • user_stats — aggregates per-user message/command counts and activity.
🔑 Example Commands
  • /joke → witty one-liner with light irony.
  • /inspire → short motivational phrase.
  • /random → unexpected witty remark.
  • /roast → sarcastic roast (no offensive targeting).
  • /stats → shows your personal stats.
  • /top → displays leaderboard.
  • /help → lists available commands.
  • @GiggleGPTBot + message → bot replies in context.
🚀 Customization Ideas
  • Add new command categories (/quote, /fact, /news).
  • Expand analytics with reaction counts or streaks.
  • Localize prompts into multiple languages.
  • Adjust CRON schedules for posts.
✅ Requirements
  • Telegram Bot token
  • OpenRouter API key
  • Postgres database
📦 Import this workflow, configure credentials, run the DB initializer — and your witty AI-powered Telegram companion is ready!
