Auto-translate incoming Gmail emails to English with OpenAI GPT-3.5
Created by: David Olusola || dae221
David Olusola
Last update a month ago
🌍 Auto-Translate Incoming Emails to English
This workflow automatically detects the language of every new Gmail email and translates non-English messages into English. The translated email is forwarded to your inbox with a clear "[TRANSLATED]" subject tag, and a label is added for easy filtering.
⚙️ How It Works
  1. Gmail New Email Trigger
    • Listens for new unread emails in your Gmail inbox.
    • Captures subject, sender, body text, and metadata.
  2. Normalize Email Data
    • A Code node extracts the raw content from the email.
    • Strips HTML, normalizes plain text, and prepares data for language detection.
  3. Detect Language (OpenAI)
    • Uses OpenAI GPT-3.5-turbo to detect the email’s language.
    • If the language is English, workflow ends.
    • If not, continues to translation.
  4. Translate to English
    • OpenAI translates the email body into clear English.
  5. Prepare Translated Email
    • Builds a forwarded email containing:
      • Original sender & subject
      • Received date
      • Message ID
      • Translated content (with formatting)
  6. Send Translated Email
    • A Gmail node sends the translated message to your inbox.
    • Subject is prefixed with [TRANSLATED] for easy recognition.
  7. Add "Translated Emails" Label
    • Automatically tags the original message in Gmail with "Translated Emails".
    • Helps you filter all auto-translated emails later.
🛠️ Setup Steps
1. Gmail Label
  • In Gmail, create a new label:
    Translated Emails
  • Or update the label in the final Gmail node.
2. OpenAI API Key
  • Get your key from platform.openai.com.
  • Add credentials in n8n.
  • Uses GPT-3.5-turbo (low cost, reliable).
3. Gmail OAuth
  • In n8n, connect your Gmail account.
  • Requires read/modify permissions.
📧 Example Output
Subject: [TRANSLATED] Meeting Proposal
Body:
🌍 AUTO-TRANSLATED EMAIL (Original Language: ES)
📧 Original From: [email protected]
📅 Received: 2025-08-29
🔗 Message ID: 123456abcdef
TRANSLATED CONTENT:
Hello, I wanted to ask if we can schedule the meeting for next week.
✨ This email was automatically translated by n8n workflow.
⚡ With this workflow, every foreign-language email is instantly translated and delivered to you in English — no manual copy-pasting into Google Translate again.
