Automate Marker.io issues to ServiceNow incidents with full technical context
Created by: Marker.io || markerio
Marker.io
Last update 23 days ago
Marker.io to ServiceNow Integration
Automatically create ServiceNow incidents with full technical context when bugs are reported through Marker.io
🎯 What this template does
This workflow creates a seamless bridge between Marker.io and ServiceNow, your IT service management platform. Every issue submitted through Marker.io's widget automatically becomes a trackable incident in ServiceNow, complete with technical details and visual context. This ensures your IT team can track, prioritize, and resolve bugs efficiently within their existing ITSM workflow.
When a bug is reported, the workflow:
  • Captures the complete Marker.io webhook payload
  • Formats all technical details and metadata
  • Creates a new incident in ServiceNow with the reporter information
  • Includes comprehensive technical context and Marker.io links
  • Preserves screenshots, browser info, and custom data
✨ Benefits
  • Automated ticket creation - No manual data entry required
  • Complete context - All bug details transfer automatically
  • Faster triage - IT teams see issues immediately in ServiceNow
  • Better tracking - Leverage ServiceNow's incident management capabilities
  • Rich debugging info - Browser, OS, and screenshot details preserved
💡 Use Cases
  • IT Service Desks: Streamline bug reporting from end users
  • Development Teams: Track production issues with full technical context
  • QA Teams: Convert test findings directly into trackable incidents
  • Support Teams: Escalate customer-reported bugs to IT with complete details
🔧 How it works
  1. N8N Webhook receives Marker.io bug report data
  2. JavaScript node formats and extracts relevant information
  3. ServiceNow node creates incident with formatted details
  4. Incident includes title, description, reporter info, and technical metadata
  5. Links preserved to both public and private Marker.io views
The result is a fully documented ServiceNow incident that your IT team can immediately action, with all the context needed to reproduce and resolve the issue.
📋 Prerequisites
  • Marker.io account with webhook capabilities
  • ServiceNow instance with API access enabled
  • ServiceNow credentials (username/password or OAuth)
  • Appropriate ServiceNow permissions to create incidents
🚀 Setup Instructions
  1. Import this workflow into your n8n instance
  2. Configure the Webhook:
    • Copy the production webhook URL after saving
    • Add to Marker.io: Workspace Settings → Webhooks → Create webhook
    • Select "Issue Created" as the trigger event
  3. Set up ServiceNow credentials:
    • In n8n, create new ServiceNow credentials
    • Enter your ServiceNow instance URL
    • Add username and password for a service account
    • Test the connection
  4. Customize field mappings (optional):
    • Modify the JavaScript code to map additional fields
    • Adjust priority mappings to match your ServiceNow setup
    • Add custom field mappings as needed
  5. Test the integration:
    • Create a test issue in Marker.io
    • Verify the incident appears in ServiceNow
    • Check that all data transfers correctly
📊 Data Captured
ServiceNow Incident includes:
  • Short Description: Issue title from Marker.io
  • Description containing:
    • 🐛 Issue title and ID
    • 📊 Priority level and issue type
    • 📅 Due date (if set)
    • 📝 Full issue description
    • 🖥️ Browser version and details
    • 💻 Operating system information
    • 🌐 Website URL where issue occurred
    • 🔗 Direct links to Marker.io issue (public and private)
    • 📦 Any custom data fields
    • 📷 Screenshot URL with proper formatting
🔄 Workflow Components
  • Webhook Node: Receives Marker.io POST requests
  • Code Node: Processes and formats the data using JavaScript
  • ServiceNow Node: Creates the incident using ServiceNow API
→ Read more about Marker.io webhook events
🚨 Troubleshooting
Webhook not triggering:
  • Verify webhook URL is correctly copied from n8n to Marker.io
  • Check that "Issue Created" event is selected in Marker.io webhook settings
  • Ensure webhook is set to "Active" status in Marker.io
  • Test with Marker.io's webhook tester feature
  • Check n8n workflow is active and not in testing mode
ServiceNow incident not created:
  • Verify ServiceNow credentials are correct and have not expired
  • Check that the service account has permissions to create incidents
  • Ensure ServiceNow instance URL is correct (include https://)
  • Test ServiceNow connection directly in n8n credentials settings
  • Check ServiceNow API rate limits haven't been exceeded
Missing or incorrect data:
  • Screenshot URL broken: The workflow already handles URL formatting, but verify Marker.io is generating screenshots
  • Custom data missing: Ensure custom fields exist in Marker.io before sending
  • Due date formatting issues: Check your ServiceNow date format requirements
JavaScript errors in Format node:
  • Check webhook payload structure hasn't changed in Marker.io updates
  • Verify all field paths match current Marker.io webhook schema
  • Use n8n's data pinning to debug with actual webhook data
  • Check for undefined values when optional fields are missing
Connection issues:
  • ServiceNow timeout: Increase timeout in node settings if needed
  • SSL/Certificate errors: Check ServiceNow instance SSL configuration
  • Network restrictions: Ensure n8n can reach your ServiceNow instance
  • Authentication failures: Regenerate ServiceNow credentials if needed
Testing tips:
  • Use n8n's "Execute Workflow" with pinned test data
  • Enable webhook test mode in Marker.io for safe testing
  • Check ServiceNow incident logs for detailed error messages
  • Monitor n8n execution logs for specific failure points
