Automate document ingestion & RAG system with Google Drive, Sheets & OpenAI
Last update 2 days ago
Categories
1. Overview
The IngestionDocs workflow is a fully automated document
ingestion and knowledge management system
built with n8n. Its
purpose is to continuously ingest organizational documents
from Google Drive, transform them into vector embeddings using
OpenAI, store them in Pinecone, and make them searchable and
retrievable through an AI-powered Q&A interface.
This ensures that employees always have access to the most up-to-date
knowledge base without requiring manual intervention.
2. Key Objectives
  • Automated Ingestion → Seamlessly process new and updated
    documents from Google Drive.\
  • Change Detection → Track and differentiate between new, updated,
    and previously processed documents.\
  • Knowledge Base Construction → Convert documents into embeddings
    for semantic search.\
  • AI-Powered Assistance → Provide an intelligent Q&A system for
    employees to query manuals.\
  • Scalable & Maintainable → Modular design using n8n, LangChain,
    and Pinecone.
3. Workflow Breakdown
A. Document Monitoring and Retrieval
  • The workflow begins with two Google Drive triggers:
    • File Created Trigger → Fires when a new document is
      uploaded.\
    • File Updated Trigger → Fires when an existing document is
      modified.\
  • A search operation lists the files in the designated Google
    Drive folder.\
  • Non-downloadable items (e.g., subfolders) are filtered out.\
  • For valid files:
    • The file is downloaded.\
    • A SHA256 hash is generated to uniquely identify the file's
      content.
B. Record Management (Google Sheets Integration)
To keep track of ingestion states, the workflow uses a Google
Sheets--based Record Manager
  • Each file entry contains:\
  • Id (Google Drive file ID)\
  • Name (file name)\
  • hashId (SHA256 checksum)\
  • The workflow compares the current file's hash with the stored one:\
  • New Document → File not found in records → Inserted into the
    Record Manager.\
  • Already Processed → File exists and hash matches → Skipped.\
  • Updated Document → File exists but hash differs → Record is
    updated.
This guarantees that only new or modified content is processed, avoiding
duplication.
C. Document Processing and Vectorization
Once a document is marked as new or updated:\
  1. Default Data Loader extracts its content (binary files
    supported).\
  • Pages are split into individual chunks.\
  • Metadata such as file ID and name are attached.\
  1. Recursive Character Text Splitter divides the content into
    manageable segments with overlap.\
  2. OpenAI Embeddings (text-embedding-3-large) transform each text
    chunk into a semantic vector.\
  3. Pinecone Vector Store stores these vectors in the configured
    index:\
  • For new documents, embeddings are inserted into a namespace based
    on the file name.\
  • For updated documents, the namespace is cleared first, then
    re-ingested with fresh embeddings.
This process builds a scalable and queryable knowledge base.
D. Knowledge Base Q&A Interface
The workflow also provides an interactive form-based user
interface
  • Form Trigger → Collects employee questions.\
  • LangChain AI Agent:\
  • Receives the question.\
  • Retrieves relevant context from Pinecone using vector similarity
    search.\
  • Processes the response using OpenAI Chat Model (gpt-4.1-mini).\
  • Answer Formatting:\
  • Responses are returned in HTML format for readability.\
  • A custom CSS theme ensures a modern, user-friendly design.\
  • Answers may include references to page numbers when available.
This creates a self-service knowledge base assistant that employees
can query in natural language.
4. Technologies Used
  • n8n → Orchestration of the entire workflow.\
  • Google Drive API → File monitoring, listing, and downloading.\
  • Google Sheets API → Record manager for tracking file states.\
  • OpenAI API:
    • text-embedding-3-large for semantic vector creation.\
    • gpt-4.1-mini for conversational Q&A.\
  • Pinecone → Vector database for embedding storage and retrieval.\
  • LangChain → Document loaders, text splitters, vector store
    connectors, and agent logic.\
  • Crypto (SHA256) → File hash generation for change detection.\
  • Form Trigger + Form Node → Employee-facing Q&A submission and
    answer display.\
  • Custom CSS → Provides a modern, responsive, styled UI for the
    knowledge base.
5. End-to-End Data Flow
  1. Employee uploads or updates a document → Google Drive detects
    the change.\
  2. Workflow downloads and hashes the file → Ensures uniqueness and
    detects modifications.\
  3. Record Manager (Google Sheets) → Decides whether to skip,
    insert, or update the record.\
  4. Document Processing → Splitting + Embedding + Storing into
    Pinecone.\
  5. Knowledge Base Updated → The latest version of documents is
    indexed.\
  6. Employee asks a question via the web form.\
  7. AI Agent retrieves embeddings from Pinecone + uses GPT-4.1-mini
    → Generates a contextual answer.\
  8. Answer displayed in styled HTML → Delivered back to the employee
    through the form interface.
6. Benefits
  • Always Up-to-Date → Automatically syncs documents when uploaded
    or changed.\
  • No Duplicates → Smart hashing ensures only relevant updates are
    reprocessed.\
  • Searchable Knowledge Base → Employees can query documents
    semantically, not just by keywords.\
  • Enhanced Productivity → Answers are immediate, reducing time
    spent browsing manuals.\
  • Scalable → New documents and users can be added without workflow
    redesign.
✅ In summary, IngestionDocs is a robust AI-driven
document ingestion and retrieval system
that integrates Google
Drive, Google Sheets, OpenAI, and Pinecone
within n8n. It
continuously builds and maintains a knowledge base of manuals while
offering employees an intelligent, user-friendly Q&A assistant for
fast and accurate knowledge retrieval.
