LinkedIn Lead Enrichment & Cold-Email Sender with Apify + OpenRouter + Gmail
Most teams spend hours hunting LinkedIn profiles, enriching company data, and writing cold emails manually.
This workflow does it all automatically: lead enrichment, email generation, and sending — directly from a simple Google Sheet.
Benefits
- Find verified LinkedIn profiles with Apify scrapers
- Enrich company data automatically from LinkedIn
- Generate fully personalized cold emails with Claude 3.7 Sonnet (OpenRouter)
- Send emails directly through Gmail
- Batch-safe with error handling so the workflow never stalls
- Log all results and errors back to Google Sheets
How It Works
- Add leads (First Name, Last Name, Company, Email) to Google Sheets
- Loop through leads in batches to avoid rate limits
- Search Google for “{First} {Last} {Company} site:linkedin.com” and keep only profile links
- Fetch person details via Apify linkedin-profile-detail (continue even if some fail)
- Enrich company data: use current_company_url or search for company page if missing
- Fetch LinkedIn company details via Apify linkedin-company-detail
- Generate subject + email body with Claude 3.7 Sonnet (validated with structured JSON output)
- Send email with Gmail OAuth2 and log status to Google Sheets
Who Is This For
- B2B founders doing manual outbound
- SDR teams building lead lists
- Lead-gen and growth agencies wanting scalable outreach
- Connect Google Sheets (select your leads sheet)
- Add Apify token for all scrapers (rag-web-browser, linkedin-profile-detail, linkedin-company-detail)
- Enter OpenRouter API key (Claude 3.7 Sonnet or preferred model)
- Connect Gmail via OAuth2
- Configure sender_name, signature, and domain settings
- Set batch size, retries, and rate-limit thresholds
ROI & Monetization
- Save 5–8 hours per week on research and copywriting
- Offer as a $1k–$3k/month outreach automation for clients
- Upsell deliverability monitoring and sequence testing for premium retainers
Strategy Insights
In the full walkthrough, I show how to:
- Build this workflow step by step with resilient error handling (
alwaysOutputData
, continue on error)
- Pitch it as a “Done-For-You Personalized Outreach System”
- Automate outreach to agencies, consultants, and SaaS teams that need enrichment
- Turn this into recurring revenue with retainers
Check Out My Channel
For more advanced AI automation systems that generate real business results, check out my YouTube channel where I share the exact strategies I use to build automation agencies, sell high-value services, and scale to $20k+ monthly revenue.
