Kubernetes deployment & pod monitoring with Telegram alerts
Created by: Vigh Sandor || vighsandor
Vigh Sandor
Last update a month ago
Categories
SETUP INSTRUCTIONS
1. Configure Kubeconfig
  • Open the "Kubeconfig Setup" node
  • Paste your entire kubeconfig file content into the kubeconfigContent variable
  • Set your target namespace in the namespace variable (default: 'production')
Example kubeconfig format:
apiVersion: v1
kind: Config
clusters:
- cluster:
    certificate-authority-data: LS0tLS1CRUd...
    server: https://your-cluster.example.com:6443
contexts:
- context:
    cluster: your-cluster
    user: your-user
current-context: your-context
users:
- name: your-user
  user:
    token: eyJhbGciOiJSUzI1...
2. Telegram Configuration
  • Create a Telegram bot via @BotFather
  • Get your bot token and add it as a credential in n8n (Telegram API)
  • Find your chat ID:
    • Message your bot
    • Visit: https://api.telegram.org/bot<YourBotToken>/getUpdates
    • Look for "chat":{"id":...}
  • Open the "Send Telegram Alert" node
  • Replace YOUR_TELEGRAM_CHAT_ID with your actual chat ID
  • Select your Telegram API credential
3. Schedule Configuration
  • Open the "Schedule Trigger" node
  • Default: runs every 1 minute
  • Adjust the interval based on your monitoring needs:
    • Every 5 minutes: Change field to minutes and set minutesInterval to 5
    • Every hour: Change field to hours and set hoursInterval to 1
    • Cron expression: Use custom cron schedule
4. kubectl Installation
  • The workflow automatically downloads kubectl (v1.34.0) during execution
  • No pre-installation required on the n8n host
  • kubectl is downloaded and used temporarily for each execution
HOW IT WORKS
Workflow Steps
  1. Schedule Trigger
    • Runs automatically based on configured interval
    • Initiates the monitoring cycle
  2. Kubeconfig Setup
    • Loads the kubeconfig and namespace configuration
    • Passes credentials to kubectl commands
  3. Parallel Data Collection
    • Get Pods: Fetches all pods from the specified namespace
    • Get Deployments: Fetches all deployments from the specified namespace
    • Both commands run in parallel for efficiency
  4. Process & Generate Report
    • Parses pod and deployment data
    • Groups pods by their owner (Deployment, DaemonSet, StatefulSet, or Node)
    • Calculates readiness statistics for each workload
    • Detects alerts: workloads with 0 ready pods
    • Generates a comprehensive Markdown report including:
      • Deployments with replica counts and pod details
      • Other workloads (DaemonSets, StatefulSets, Static Pods)
      • Standalone pods (if any)
      • Pod-level details: status, node, restart count
  5. Has Alerts?
    • Checks if any workloads have 0 ready pods
    • Routes to appropriate action
  6. Send Telegram Alert (if alerts exist)
    • Sends formatted alert message to Telegram
    • Includes:
      • Namespace information
      • List of problematic workloads
      • Full status report
  7. Save Report
    • Saves the Markdown report to a file
    • Filename format: k8s-report-YYYY-MM-DD-HHmmss.md
    • Always executes, regardless of alert status
Security Features
  • Temporary kubectl: Downloaded and used only during execution
  • Temporary kubeconfig: Written to /tmp/kubeconfig-<random>.yaml
  • Automatic cleanup: Kubeconfig file is deleted after each kubectl command
  • No persistent credentials: Nothing stored on disk between executions
Alert Logic
Alerts are triggered when any workload has zero ready pods:
  • Deployments with readyReplicas < 1
  • DaemonSets with numberReady < 1
  • StatefulSets with readyReplicas < 1
  • Static Pods (Node-owned) with no ready instances
Report Sections
  1. Deployments: All Deployment-managed pods (via ReplicaSets)
  2. Other Workloads: DaemonSets, StatefulSets, and Static Pods (kube-system components)
  3. Standalone Pods: Pods without recognized owners (rare)
  4. Alerts: Summary of workloads requiring attention
KEY FEATURES
  • Automatic kubectl management - No pre-installation needed
  • Multi-workload support - Deployments, DaemonSets, StatefulSets, Static Pods
  • Smart pod grouping - Uses Kubernetes ownerReferences
  • Conditional alerting - Only notifies when issues detected
  • Detailed reporting - Pod-level status, node placement, restart counts
  • Secure credential handling - Temporary files, automatic cleanup
  • Markdown format - Easy to read and store
TROUBLESHOOTING
Issue: "Cannot read properties of undefined"
  • Ensure both "Get Pods" and "Get Deployments" nodes execute successfully
  • Check that kubectl can access your cluster with the provided kubeconfig
Issue: No alerts when there should be
  • Verify the namespace contains deployments or workloads
  • Check that pods are actually not ready (use kubectl get pods -n <namespace>)
Issue: Telegram message not sent
  • Verify Telegram API credential is configured correctly
  • Confirm chat ID is correct and the bot has permission to message you
  • Check that the bot was started (send /start to the bot)
Issue: kubectl download fails
  • Check internet connectivity from n8n host
  • Verify access to dl.k8s.io domain
  • Consider pre-installing kubectl on the host and removing the download commands
CUSTOMIZATION
Change Alert Threshold
Edit the Process & Generate Report node to change when alerts trigger:
// Change from "< 1" to your desired threshold
if (readyReplicas < 2) {  // Alert if less than 2 ready pods
  alerts.push({...});
Monitor Multiple Namespaces
  • Duplicate the workflow for each namespace
  • Or modify "Kubeconfig Setup" to loop through multiple namespaces
Custom Report Format
Edit the markdown generation in Process & Generate Report node to customize:
  • Section order
  • Information displayed
  • Formatting style
Additional Notification Channels
Add nodes after "Has Alerts?" to send notifications via:
  • Email (SMTP node)
  • Slack (Slack node)
  • Discord (Discord node)
  • Webhook (HTTP Request node)
