Food image analysis for calorie estimation with Vision AI and Telegram
Created by: Toshiya Minami || minami
Toshiya Minami
Last update a month ago
Who’s it for
Teams building health/fitness apps, coaches running check-ins in chat, and anyone who needs quick, structured nutrition insights from food photos—without manual logging.
What it does / How it works
This workflow accepts a food image (URL or Base64), uses a vision-capable LLM to infer likely ingredients and rough gram amounts, estimates per-ingredient calories, and returns a strict JSON summary with total calories and a short nutrition note. It normalizes different payloads (e.g., Telegram/LINE/Webhook) into a common format, handles transient errors with retries, and avoids hardcoded secrets by using credentials/env vars.
Requirements
  • Vision-capable LLM credentials (e.g., gpt-4o or equivalent)
  • One input channel (Webhook, Telegram, or LINE)
  • Environment variables for model name/temperature and optional request validation
How to set up
  1. Connect your input channel and enable the Webhook (copy the test URL).
  2. Add LLM credentials and set LLM_MODEL and LLM_TEMPERATURE (e.g., 0.3).
  3. Turn on the workflow, send a sample payload with imageUrl, and confirm the strict JSON output.
  4. (Optional) Configure a reply node (Telegram/Slack or HTTP Response) and a logger (Google Sheets/Notion).
How to customize the workflow
  • Outputs: Add macros (protein/fat/carb) or micronutrient fields.
  • Units: Convert portion descriptions (piece/slice) to grams with your own mapping.
  • Languages: Toggle multilingual output (ja/en).
  • Policies: Tighten validation (reject low-confidence parses) or add manual review steps.
  • Security: Use signed/temporary URLs for private images; mask PII in logs.
Data model (strict JSON)
  "dishName": "string",
  "ingredients": [{ "name": "string", "amount": 0, "calories": 0 }],
  "totalCalories": 0,
  "nutritionEvaluation": "string"
Notes
Rename all nodes clearly, include sticky notes explaining the setup, and never commit real IDs, tokens, or API keys.
