Create knowledge base from Jira tickets with OpenAI embeddings and Pinecone
Created by: yusan25c || yusan25c
yusan25c
Last update a month ago
How It Works
This template is a workflow that registers Jira tickets to Pinecone.
By combining it with the Automated Jira Ticket Responses with GPT-4 and Pinecone Knowledge Base template, you can continuously improve the quality of automated responses in Jira.
Prerequisites
  • A Jira account and credentials (API key and email address)
  • A Pinecone account and credentials (API key and environment settings)
  • OpenAI credentials (API key)
Setup Instructions
  1. Jira Credentials
    • Register your Jira credentials (API key and email address) in n8n.
  2. Vector Database Setup (Pinecone)
    • Register your Pinecone credentials (API key and environment variables) in n8n.
  3. AI Node
    • Configure the OpenAI node with your credentials (API key).
Step by Step
  1. Scheduled Trigger
    The workflow runs at regular intervals according to the schedule set in the Scheduled Trigger node.
  2. Jira Trigger (Completed Tickets)
    Retrieves the summary, description, and comments of completed Jira tickets.
  3. Register to Pinecone
    Converts the retrieved ticket information into vectors and registers them in Pinecone.
Notes
  • Configure the Scheduled Trigger interval carefully to avoid exceeding API rate limits.
Further Reference
For a detailed walkthrough (in Japanese), see this article:
👉 Automating knowledge registration to Pinecone with n8n (Qiita)
You can find the template file on GitHub here:
👉 Template File on GitHub
