Automate property maintenance requests with GPT-4o-mini, Jotform and Gmail
Created by: Jitesh Dugar || jiteshdugar
Jitesh Dugar
Last update a month ago
Tired of juggling maintenance calls, lost requests, and slow vendor responses?
This workflow streamlines the entire property maintenance process — from tenant request to vendor dispatch — powered by AI categorization and automated communication.
Cut resolution time from 5–7 days to under 24 hours and boost tenant satisfaction by 85% with zero manual follow-up.
What This Workflow Does
Transforms chaotic maintenance management into seamless automation:
📝 Captures Requests – Tenants submit issues via Jotform with unit number, issue description, urgency, and photos.
🤖 AI Categorization – OpenAI (GPT-4o-mini) analyzes and classifies issues (plumbing, HVAC, electrical, etc.).
⚙️ Smart Prioritization – Flags emergencies (leak, electrical failure) and assigns priority.
📬 Vendor Routing – Routes issue to the correct contractor or vendor based on AI category.
📧 Automated Communication – Sends acknowledgment to tenant and work order to vendor via Gmail.
📊 Audit Trail Logging – Optionally logs requests in Google Sheets for performance tracking and reporting.
Key Features
🧠 AI-Powered Categorization – Intelligent issue type and priority detection.
🚨 Emergency Routing – Automatically escalates critical issues.
📤 Automated Work Orders – Sends detailed emails with property and tenant info.
📈 Google Sheets Logging – Transparent audit trail for compliance and analytics.
🔄 End-to-End Automation – From form submission to vendor dispatch in seconds.
💬 Sticky Notes Included – Every section annotated for easy understanding.
Perfect For
  1. Property management companies
  2. Real estate agencies and facility teams
  3. Smart building operators
  4. Co-living and rental startups
  5. Maintenance coordinators managing 50–200+ requests monthly
What You’ll Need
Required Integrations:
  1. Jotform – Maintenance request form
    Create your form for free on Jotform using this link
  2. OpenAI (GPT-4o-mini) – Categorization and prioritization
  3. Gmail – Automated email notifications
  4. (Optional) Google Sheets – Logging and performance tracking
Quick Start
  1. Import Template – Copy JSON into n8n and import.
  2. Create Jotform – Include fields:
    Tenant name, email, unit number, issue description, urgency, photo upload.
  3. Add Credentials – Configure Jotform, Gmail, and OpenAI credentials.
  4. Set Vendor Emails – Update “Send to Contractor” Gmail node with vendor email IDs.
  5. Test Workflow – Submit sample maintenance requests for AI categorization and routing.
  6. Activate Workflow – Go live and let your tenants submit maintenance issues.
Expected Results
⏱️ 24-hour average resolution time (vs 5–7 days).
😀 85% higher tenant satisfaction with instant communication.
📉 Zero lost requests – every issue logged automatically.
🧠 AI-driven prioritization ensures critical issues handled first.
🕒 10+ hours saved weekly for property managers.
Pro Tips
🧾 Add Google Sheets logging for a complete audit trail.
🔔 Include keywords like “leak,” “no power,” or “urgent” in AI prompts for faster emergency detection.
🧰 Expand vendor list dynamically using a Google Sheet lookup.
🧑‍🔧 Add follow-up automation to verify task completion from vendors.
📊 Create dashboards for monthly maintenance insights.
Learning Resources
This workflow demonstrates:
  1. AI categorization using OpenAI’s Chat Model (GPT-4o-mini)
  2. Multi-path routing logic (emergency vs. normal)
  3. Automated communication via Gmail
  4. Optional data logging in Google Sheets
  5. Annotated workflow with Sticky Notes for learning clarity
