Automate cross-project dependency tracking between Jira and Monday
Created by: Rahul Joshi || rahul08
Rahul Joshi
Last update a month ago
Description
Keep your product and project teams perfectly aligned by automatically syncing task dependencies between Jira and Monday.com. This workflow ensures real-time visibility into cross-platform blockers and dependencies, allowing smoother delivery across multiple teams and tools. 🔄📅💼
What This Template Does
  • Step 1: Trigger the workflow on a schedule or manual run.
  • Step 2: Fetch project tasks and dependencies from Jira.
  • Step 3: Retrieve matching items from Monday.com based on linked project IDs or issue keys.
  • Step 4: Compare dependencies between both systems.
  • Step 5: Identify mismatched or missing dependencies across platforms.
  • Step 6: Send summarized reports to Slack or Gmail for team visibility.
  • Step 7: Optionally update Monday.com or Jira items with dependency status tags.
Key Benefits
✅ Maintain alignment across multiple projects and teams.
✅ Detect and resolve dependency conflicts before they cause delays.
✅ Automate visibility — no more manual cross-checking.
✅ Simplify multi-tool management for product and engineering leads.
Features
  • Integration between Jira Cloud and Monday.com API
  • Cross-dependency comparison logic
  • Scheduled or manual execution
  • Slack/Gmail notifications for updates or conflicts
  • Custom mapping for project and issue identifiers
Requirements
  • Jira Cloud account with API credentials
  • Monday.com API key or OAuth2 token
  • Optional: Slack or Gmail credentials for notifications
  • n8n instance (cloud or self-hosted)
Target Audience
  • Product and Project Managers coordinating across tools 🧩
  • Engineering Leads overseeing multi-platform sprints ⚙️
  • PMOs managing dependencies across cross-functional teams 📊
  • Operations teams aiming for unified delivery visibility 📈
Step-by-Step Setup Instructions
  • Connect your Jira and Monday.com credentials in n8n.
  • Map project identifiers or keys between Jira and Monday.com.
  • (Optional) Configure Slack or Gmail for daily status alerts.
  • Adjust the cron expression to match your monitoring schedule.
  • Run the workflow once manually to validate mappings.
  • Activate the workflow for ongoing dependency tracking. ✅
