Generate invoices and send AI-powered reminders with Jotform and Xero
Created by: AppUnits AI || appunitsai
AppUnits AI
Last update a month ago
Generate Invoices and Send Reminders for Customers with Jotform and Xero
This workflow automates the entire process of receiving a product/service order, checking or creating a customer in Xero, generating an invoice, emailing it — all triggered by a form submission (via Jotform), and sending invoice reminders.
How It Works
  1. Receive Submission
  • Triggered when a user submits a form.
  • Collects data like customer details, selected product/service, etc.
  1. Create/Update The Customer
  • Creates/Updates the customer.
  1. Create The Invoice
  • Generates a new invoice for the customer using the item selected.
  1. Send The Invoice
  • Automatically sends the invoice via email to the customer.
  1. Store The Invoice In DB
  • Stores the needed invoice details in the DB.
  1. Send Reminders
  • Every day at 8 AM, the automation checks each invoice to decide whether to:
    • send a reminder email,
    • skip and send it later, or
    • delete the invoice from the DB (if it's paid or all reminders have been sent).
Who Can Benefit from This Workflow?
  • Freelancers
  • Service Providers
  • Consultants & Coaches
  • Small Businesses
  • E-commerce or Custom Product Sellers
Requirements
  • Jotform webhook setup, more info here
  • Xero credentials, more info here
  • Make sure that products/services values in Jotform are exactly the same as your item Code in your Xero account
  • Email setup, update email nodes (Send email & Send reminder email & Send reminders sent summary)
  • Create data table with the following columns:
    • invoiceId (string)
    • remainingAmount (number)
    • currency (string)
    • remindersSent (number)
    • lastSentAt (date time)
  • Update Add reminders config node so update the data table id and intervals in days (default is after 2 days, then after 3 days and finally after 5 days )
  • LLM model credentials
