Monitor PKI certificates & CRLs for expiration with Telegram & SMS alerts
Created by: Vigh Sandor || vighsandor
Vigh Sandor
Last update 4 months ago
Categories
PKI Certificate & CRL Monitor - Auto Expiration Alert System
Overview
This n8n workflow provides automated monitoring of Public Key Infrastructure (PKI) components including CA certificates, Certificate Revocation Lists (CRLs), and associated web services. It extracts certificate information from the TSL (Trusted Service List) -- the Hungarian is the example list as default in the workflow -- , monitors expiration dates, and sends alerts via Telegram and SMS when critical thresholds are reached.
Features
  • Automated extraction of certificate URLs from TSL XML
  • CA certificate expiration monitoring
  • CRL expiration tracking
  • Website availability monitoring with retry mechanism
  • Multi-channel alerting (Telegram and SMS)
  • Scheduled execution every 12 hours
  • 17-hour warning threshold for expirations
Setup Instructions
Prerequisites
  1. n8n Instance: Running n8n installation with Linux environment
  2. Telegram Bot: Created via @BotFather
  3. Textbelt API Key: For SMS notifications (optional)
  4. Network Access: To reach TSL source and certificate URLs
  5. Linux Tools: OpenSSL, curl, libxml2-utils, jq (auto-installed)
Configuration Steps
1. Telegram Setup
Create Telegram Bot:
  • Open Telegram and search for @BotFather
  • Send /newbot and follow prompts
  • Save the bot token (format: 1234567890:ABCdefGHIjklMNOpqrsTUVwxyz)
Create Alert Channel:
  • Create a new Telegram channel for alerts
  • Add your bot as administrator
  • Get channel ID:
    • Send a test message to the channel
    • Visit: https://api.telegram.org/bot<YOUR_BOT_TOKEN>/getUpdates
    • Find "chat":{"id":-100XXXXXXXXXX} - this is your channel ID
2. SMS Setup (Optional)
Textbelt Configuration:
  • Register at https://textbelt.com
  • Purchase credits and obtain API key
  • Note: Free tier allows 1 SMS/day for testing
3. Configure Alert Nodes
Update these nodes with your credentials:
CRL Alert Node:
  • Open CRL Alert --- Telegram & SMS node
  • Replace YOUR-TELEGRAM-BOT-TOKEN with your bot token
  • Replace YOUR-TELEGRAM-CHANNEL-ID with your channel ID
  • Replace +36301234567 with target phone number(s)
  • Replace YOUR-TEXTBELT-API-KEY with your Textbelt key
CA Alert Node:
  • Open CA Alert --- Telegram & SMS node
  • Apply same replacements as above
Website Down Alert Node:
  • Open Send Website Down - Telegram & SMS node
4. TSL Source Configuration
The workflow defaults to Hungarian TSL:
5. Threshold Configuration
Default warning threshold: 17 hours before expiration
  • To modify CRL threshold: Edit nextUpdate - TimeFilter node
  • To modify CA threshold: Edit nextUpdate - TimeFilter1 node
  • Change value in condition: if (diffHours < 17)
Activation
  1. Save all configuration changes
  2. Test with Execute With Manual Start trigger
  3. Verify alerts are received
  4. Toggle workflow to Active status for scheduled operation
How to Use
Automatic Operation
Once activated, the workflow runs automatically:
  • Frequency: Every 12 hours
  • Process:
    1. Downloads TSL XML
    2. Extracts all certificate URLs
    3. Checks each URL type (CRL, CA, or other)
    4. Validates expiration dates
    5. Sends alerts for critical items
Manual Execution
For immediate checks:
  1. Open the workflow
  2. Click Execute With Manual Start node
  3. Click "Execute Node"
  4. Monitor execution progress
Understanding Alerts
CRL Expiration Alert
Message Format:
ALERT! with [Issuer CN] !!!CRL EXPIRATION!!! Will be under 17 hour ([Next Update Time])! Last updated: [Last Update Time]
Trigger Conditions:
  • CRL expires in less than 17 hours
  • CRL download successful but expiration imminent
CA Certificate Alert
Message Format:
ALERT!/EXPIRED! with [Subject CN] !!!CA EXPIRATION PROBLEM!!! The expiration time: ([Not After Date]) Last updated: ([Not Before Date])
Trigger Conditions:
  • Certificate expires in less than 17 hours (ALERT!)
  • Certificate already expired (EXPIRED!)
Website Down Alert
Message Format:
ALERT! The [URL] !!!NOT AVAILABLE!!! Service outage probable! Intervention required!
Trigger Conditions:
  • Initial HTTP request fails
  • Retry after wait period also fails
  • HTTP status code not 200
Monitoring Dashboard
Execution History
  • Navigate to n8n Executions tab
  • Filter by workflow name
  • Review successful/failed runs
Alert History
Check Telegram channel for:
  • Alert timestamps
  • Affected certificates/services
  • Expiration details
Troubleshooting
No Alerts Received
  1. Check Telegram Bot:
    • Verify bot is admin in channel
    • Test with manual message via API
    • Confirm channel ID is correct
  2. Check Workflow Execution:
    • Review execution logs in n8n
    • Look for error nodes (red indicators)
    • Verify TSL URL is accessible
False Positives
  • Verify system time is correct
  • Check timezone settings
  • Review threshold values
Missing Certificates
  • Some certificates may not have URLs
  • TSL may be temporarily unavailable
  • Check XML parsing in logs
Performance Issues
Slow Execution:
  • Large TSL files take time to parse
  • Network latency affects URL checks
  • Consider increasing timeout values
Memory Issues:
  • Workflow processes many URLs sequentially
  • Monitor n8n server resources
  • Consider increasing batch intervals
Advanced Configuration
Modify Check Frequency
Edit Execute With Scheduled Start node:
  • Change interval type (hours/days/weeks)
  • Adjust interval value
  • Consider peak/off-peak scheduling
Add Custom TSL Sources
In Collect Checking URL list node:
URL="https://your-tsl-source.com/tsl.xml"
Customize Alert Messages
Edit alert nodes to modify message templates:
  • Add organization name
  • Include escalation contacts
  • Add remediation instructions
Filter Certificate Types
Modify URL detection patterns:
  • Is this CRL? node: Adjust CRL detection
  • Is this CA? node: Adjust CA detection
  • Add new patterns as needed
Adjust Retry Logic
Wait B4 Retry node:
  • Default: Immediate retry
  • Can add delay (seconds/minutes)
  • Useful for transient network issues
Maintenance
Regular Tasks
  • Weekly: Review alert frequency
  • Monthly: Validate phone numbers/channels
  • Quarterly: Update TSL source URLs
  • Annually: Review threshold values
Log Management
  • Clear old execution logs periodically
  • Archive alert history from Telegram
  • Document false positives for tuning
Updates
  • Keep n8n updated for security patches
  • Monitor OpenSSL versions for compatibility
  • Update notification service APIs as needed
Security Considerations
  • Store API keys in n8n credentials manager
  • Use environment variables for sensitive data
  • Restrict workflow edit access
  • Monitor for unauthorized changes
  • Regularly rotate API keys
  • Use HTTPS for TSL sources when available
Compliance Notes
  • Ensure monitoring aligns with PKI policies
  • Document alert response procedures
  • Maintain audit trail of certificate issues
  • Consider regulatory requirements for uptime
Integration Options
  • Connect to ticketing systems for alert tracking
  • Add database logging for compliance
  • Integrate with monitoring dashboards
  • Create escalation workflows for critical alerts
Best Practices
  1. Test alerts monthly to ensure delivery
  2. Maintain multiple notification channels
  3. Document response procedures for each alert type
  4. Set up redundant monitoring if critical
  5. Review and tune thresholds based on operational needs
  6. Keep contact lists updated
  7. Consider time zones for global operations
