Generate Shopify product listings from images with Gemini AI and Airtable
Created by: MANISH KUMAR || manipritraj
MANISH KUMAR
Last update 19 days ago
Shopify Digital Product Automation
(from just and image to complete Shopify product page.)
This Shopify Digital Product Automation is an advanced n8n-powered workflow that leverages AI (Google Gemini), Airtable, and Shopify API to generate product details from images and automatically post them to Shopify. It fully automates the process — from uploading images to publishing Shopify products — with minimal manual effort.
💡 Key Advantages
Our Shopify Digital Product Automation offers five core advantages:
  • 🔗 Shopify Product Sync — Automatically posts product details including title, description, SEO fields, and matched category to Shopify.
  • ✍️ AI-Powered Product Generation — Gemini analyzes uploaded images and generates engaging, SEO-friendly product titles, descriptions, and metadata.
  • 🗂️ Structured Output — Outputs JSON-ready product data compatible with Shopify, ensuring smooth automation.
  • 📄 Airtable Integration — Tracks uploaded images, analyzed data, and generated products to prevent duplication.
  • 📤 End-to-End Automation — Handles the complete workflow from image upload to Shopify posting without manual intervention.
⚙️ How It Works
The workflow follows a step-by-step automated process:
Step-by-Step Process
  1. Upload Images – Add your digital artwork or poster images to Google Drive and record them in Airtable.
  2. Image Analysis – AI fetches new images and analyzes visual elements like characters, series, poster text, and style.
  3. Store Analysis Results – Updates analyzed data in Airtable and marks images as Used.
  4. Fetch Shopify Collections – Retrieves current collections from your Shopify store for category matching.
  5. Generate Product Details – Gemini generates product title, description, matched category, SEO page title, meta description, and URL handle.
  6. Save Generated Products – Stores generated product details in Airtable and marks them as generated.
  7. Post Products to Shopify – Automatically creates new products in Shopify using the API.
  8. Update Status – Marks products as posted in Airtable after successful posting.
🛠️ Setup Steps
Required Node Configuration
To implement this workflow, configure the following n8n nodes:
  • Trigger Node – Start workflow manually or via scheduler.
  • Airtable Node – Fetch raw images and store processed product details.
  • Google Drive Node – Access image files.
  • HTTP Request Node – Fetch Shopify collections.
  • Code Node – Refine AI outputs and format product data.
  • Split & Limit Nodes – Process images and products in batches.
  • LangChain / Gemini Node – Generate product titles, descriptions, and SEO data.
  • Shopify Node – Create products via Shopify API.
  • Status Update Node – Update Airtable with processing and posting status.
🔐 Credentials Required
Before running the workflow, ensure you have the following credentials configured:
  • Shopify Access Token – For posting products and fetching collections.
  • Gemini API Key – For AI-powered product generation.
  • Airtable API Key – For storing and tracking workflow data.
  • Google Drive OAuth – To access image files.
👤 Ideal For
This automation workflow is designed for:
  • Shopify store owners managing hundreds of digital products
  • Ecommerce teams automating product listings
  • Marketing teams needing scalable, AI-driven product content workflows
💬 Bonus Tip
The workflow is fully modular and customizable. You can extend it to:
  • Automatically assign prices or discounts
  • Multi-language product description generation
  • Social media promotion of new products
  • Email campaign integration
All extensions can be implemented within the same n8n flow, making it a complete digital product automation solution.
