Audio transcription with Telegram and Groq Whisper
Created by: Abhiman || abhimangs
Abhiman
Last update a day ago
Short description
Transcribe Telegram voice/audio messages to text using Groq’s OpenAI-compatible Whisper endpoint. Replies are delivered either as a Telegram message or as a downloadable .txt file, plug-and-play for n8n with minimal setup.
Who’s it for / Uses
  • Educators, podcasters, interviewers, and support teams who need quick voice → text conversions.
  • Automating meeting notes, voice feedback, voicemail transcription, or speech logging.
  • Useful when you want transcripts pushed to chat or saved as files for archiving.
How it works (overview)
  1. Telegram Trigger — workflow starts on incoming message.
  2. Switch (Audio/Voice) — detects voice or audio. If neither, replies “Wrong file type” and stops.
  3. Telegram Download — downloads the audio using the file_id, outputs file path/binary.
  4. Set Node (credentials + options) — stores Groq_API and Telegram_access_token (required) and transcript_output_format (message or file).
  5. HTTP Request → Groq (Whisper) — uploads audio (multipart/form-data) to Groq’s transcription endpoint and receives text.
  6. Reply Switch — routes to either:
    • Message branch: send transcribed text as a Telegram message.
    • File branch: convert transcript to .txt and send as a document.
Requirements
  • n8n instance (cloud or self-hosted) with internet access
  • Telegram bot token (create via BotFather)
  • Groq API key (create at https://console.groq.com/keys)
  • Basic n8n nodes: Telegram Trigger, Switch, Telegram Download, Set, HTTP Request, Convert to File, Telegram Send Message/Document
Important setup & notes
  • Mandatory: Add Groq_API and Telegram_access_token in the Set node (or use n8n Credentials). The workflow will fail without them.
  • Do not hardcode keys in HTTP node fields that will be exported/shared. Use Set fields or n8n Credentials.
  • Include sticky notes explaining each node (yellow note with full description recommended). Sticky notes should show setup steps and required fields.
  • Before publishing: remove personal IDs and secrets, test with sample voice messages, and verify Groq response schema to map the transcript field correctly.
Security & best practices
  • Use n8n Credentials or environment variables in production.
  • Rotate API keys if they become exposed.
  • Keep the Set node private when sharing templates; instruct users to replace keys with their own.
