Synchronizing WooCommerce inventory and creating products with Google Gemini AI and BrowserAct
Last update 22 days ago
Categories
Synchronize WooCommerce Inventory
Synchronize WooCommerce Inventory & Create Products with Gemini AI & BrowserAct
This sophisticated n8n template automates WooCommerce inventory management by scraping supplier data, updating existing products, and intelligently creating new ones with AI-formatted descriptions.
This workflow is essential for e-commerce operators, dropshippers, and inventory managers who need to ensure their product pricing and stock levels are synchronized with multiple third-party suppliers, minimizing overselling and maximizing profit.
Self-Hosted Only
This Workflow uses a community contribution and is designed and tested for self-hosted n8n instances only.
  • The workflow is typically run by a Schedule Trigger (though a Manual Trigger is also shown) to check stock automatically.
  • It reads a list of suppliers and their inventory page URLs from a central Google Sheet.
  • The workflow loops through each supplier:
    • A BrowserAct node scrapes the current stock and price data from the supplier's inventory page.
    • A Code node parses this bulk data into individual product items.
    • It then loops through each individual product found.
  • The workflow checks WooCommerce to see if the product already exists based on its name.
    • If the product exists: It proceeds to update the existing product's price and stock quantity.
    • If the product DOES NOT exist:
      • An If node checks if the missing product's category matches a predefined type (optional filtering).
      • If it passes the filter, a second BrowserAct workflow scrapes detailed product attributes from a dedicated product page (e.g., DigiKey).
      • An AI Agent (Gemini) transforms these attributes into a specific, styled HTML table for the product description.
      • Finally, the product is created in WooCommerce with all scraped details and the AI-generated description.
  • Error Handling: Multiple Slack nodes are configured to alert your team immediately if any scraping task fails or if the product update/creation process encounters an issue.
Note: This workflow does not support image uploads for new products. To enable this functionality, you must modify both the n8n and BrowserAct workflows.
Requirements
  • BrowserAct API account for web scraping
  • BrowserAct n8n Community Node -> (n8n Nodes BrowserAct)
  • BrowserAct templates named “WooCommerce Inventory & Stock Synchronization” and “WooCommerce Product Data Reconciliation”
  • Google Sheets credentials for the supplier list
  • WooCommerce credentials for product management
  • Google Gemini account for the AI Agent
  • Slack credentials for error alerts
Need Help?
Workflow Guidance and Showcase
