AI-powered document search with Oracle and ONNX embeddings for recruiting
Created by: sudarshan || sudarshansoma
sudarshan
Last update 25 days ago
  1. Create a user for doing Hybrid Search.
  2. Clear Existing Data, if present.
  3. Add Documents into the table.
  4. Create a hybrid index.
  5. Run Semantic search on the Documents table for "prioritize teamwork and leadership experience".
  6. Run Hybrid search for the text input in the Chat interface on the Documents table.
Setup Steps
Download the ONNX model
all_MiniLM_L12_v2_augmented.zip
Extract the ZIP file on the database server into a directory, for example /opt/oracle/onnx.
After extraction, the folder contents should look like:
bash-4.4$ pwd
/opt/oracle/onnx
bash-4.4$ ls
all_MiniLM_L12_v2.onnx
Connect as SYSDBA and create the DBA user
-- Create DBA user
CREATE USER app_admin IDENTIFIED BY "StrongPassword123"
  DEFAULT TABLESPACE users
  TEMPORARY TABLESPACE temp
  QUOTA UNLIMITED ON users;
-- Grant privileges
GRANT DBA TO app_admin;
GRANT CREATE TABLESPACE, ALTER TABLESPACE, DROP TABLESPACE TO app_admin;
Create n8n Oracle DB credentials
  • hybridsearchuser → for hybrid search operations
  • dbadocuser → for DBA setup (user and tablespace creation)
Run the workflow
Click the manual Trigger
  • It displays Pure semantic search results.
Enter search text in Chat interface
  • It displays results for vector and keyword search.
Note
  • The workflow currently creates the hybrid search user, docuser with the password visible in plain text inside the n8n Execute SQL node.
  • For better security, consider performing the user creation manually outside n8n.
  • Oracle 23ai or 26ai Database has to be used.
Reference
Hybrid Search End-End Example
