Automate Telegram channel post reactions with bot rotation & GPT-5-mini
Created by: Cj Elijah Garay || elijahbuilds-ai
Cj Elijah Garay
Last update a month ago
📋 WORKFLOW OVERVIEW
Automate reactions for Telegram Channel Posts - Automated Telegram reaction system for specific posts
Flow:
  1. User sends message to a receiver bot
  2. AI parses request (emoji type & quantity)
  3. Code processes and validates data
  4. Loop sends reactions one by one
  5. User receives confirmation
Key Features:
  • Natural language processing by sending a message to a chat bot to react to a post on a different channel
  • Reiterates through bot token rotation. This means that if you use 100 bots then you will be able to have 100 reactions per post of your choice
  • Rate limit protection
  • Error handling with helpful messages
You will need to first add the bots that you personally own which can be acquired from BotFather to the channel that you would want them to react posts to and allow it to manage messages.
Required Bot Permissions:
  1. Bot Must Be an Administrator
    The bot needs to be added as an admin to the channel (regular member status won't work for reactions).
  2. Specific Admin Rights Needed:
    When adding the bot as admin, you need to enable:
    ✅ "Post Messages" - This is actually the key permission needed
    ✅ "Add Subscribers" (optional, but sometimes required depending on channel settings)
Credentials needed are:
Target Channel ID, Bot tokens, Bot Receiver token, OpenAI API
Example Usage:
If in need of help contact me at:
[email protected]
