Automate Instagram complaint handling with Claude AI, tickets & SLA management
Last update a month ago
This enterprise-grade n8n workflow automates the Instagram complaint handling process — from detection to resolution — using Claude AI, dynamic ticket assignment, and SLA enforcement. It converts customer complaints in comments into actionable support tickets with auto-assignment, escalation alerts, and full audit trails, ensuring timely responses and improved customer satisfaction with zero manual intervention.
Key Features
  • Real-time Instagram polling for new comments
  • AI-powered complaint detection using Claude 3.5 Sonnet for sentiment and issue classification
  • Automatic ticket creation in Google Sheets (or integrable with Zendesk/Jira)
  • Round-robin assignment to team members from a dynamic roster
  • SLA timer and monitoring (e.g., 24-hour response window with escalation at 80% elapsed)
  • Escalation engine notifies managers via Slack if near breach
  • Multi-channel notifications: Slack for assignees and escalations
  • Audit-ready: Logs ticket details, assignments, and actions
  • Scalable triggers: Webhook or scheduled polling
Workflow Process
Step Node Description
1 Schedule Trigger Runs every 15 minutes or via webhook (/complaint-handler)
2 Get Instagram Posts Fetches recent posts from Instagram Graph API
3 Get Comments Retrieves comments for the latest post
4 Loop Over Comments Processes each comment individually to avoid rate limits
5 Detect Complaint (Claude AI) Uses AI to classify if complaint, extract issue/severity
6 IF Complaint Branches: Proceed if yes, end if no
7 Get Team Members Loads team roster from TeamMembers sheet
8 Assign Ticket Sets assignee via round-robin logic
9 Create Ticket (Google Sheet) Appends new ticket with details and SLA due date
10 Notify Assignee (Slack) Alerts assigned team member
11 Wait for SLA Check Delays to near-SLA-breach point (e.g., 20 hours)
12 Check Ticket Status Looks up ticket status in sheet
13 IF SLA Breach Near Checks if unresolved; escalates if yes
14 Escalate to Manager (Slack) Notifies manager for urgent action
15 End (Non-Complaint Path) Terminates non-complaint branches
Setup Instructions
1. Import Workflow
  • Open n8n → Workflows → Import from Clipboard
  • Paste the JSON workflow
2. Configure Credentials
Integration Details
Instagram API Access token from Facebook Developer Portal
Claude AI Anthropic API key for claude-3-5-sonnet-20241022
Google Sheets Service account with spreadsheet access
Slack Webhook or OAuth app
3. Update Spreadsheet IDs
Ensure your Google Sheets include:
  • SupportTickets
  • TeamMembers
4. Set Triggers
  • Webhook: /webhook/complaint-handler (for real-time Instagram notifications if set up)
  • Schedule: Every 15 minutes
5. Run a Test
Use manual execution to confirm:
  • Ticket creation in sheet
  • Slack notifications
  • SLA wait and escalation logic (simulate by shortening wait time)
Google Sheets Structure
SupportTickets
ticketId commentText user createdAt assignedTo status slaDue issueType severity
TKT-12345678 Sample complaint text user123 2023-10-01T12:00:00Z [email protected] Open 2023-10-02T12:00:00Z Product Issue Medium
TeamMembers
name email
John Doe [email protected]
Jane Smith [email protected]
System Requirements
Requirement Version/Access
n8n v1.50+ (AI integrations supported)
Claude AI API claude-3-5-sonnet-20241022
Instagram Graph API Business account access token
Google Sheets API https://www.googleapis.com/auth/spreadsheets
Slack Webhook Required for notifications
Optional Enhancements
  • Integrate Zendesk/Jira for professional ticketing instead of Google Sheets
  • Add email notifications to customers acknowledging complaints
  • Use sentiment thresholds for prioritizing high-severity tickets
  • Connect Twilio for SMS escalations
  • Enable multi-platform support (e.g., Twitter/Facebook comments)
  • Add reporting dashboard via Google Data Studio
  • Implement auto-resolution for simple complaints using AI responses
Result:
A single automated system that detects, tickets, assigns, and enforces SLAs on Instagram complaints — with full AI intelligence and zero manual work.
Explore More AI Workflows: Get in touch with us for custom n8n automation!
