Create a searchable document archive with Telegram, Drive, OCR and Airtable
Last update a month ago
This n8n workflow receives files sent in a Telegram chat, uploads them to Google Drive, extracts text using OCR (for images and PDFs), and stores the extracted content in Airtable for quick search and retrieval.
Users can later search through documents using a Telegram /search command.
Key Features
  • Accepts images and documents from Telegram
  • Uploads files to Google Drive automatically
  • Detects file type and runs OCR if eligible
  • Extracts text from images & PDFs via Google Vision
  • Stores file metadata + text in Airtable
  • Search documents using /search command in Telegram
  • Sends result previews and file links
  • Error handling & user notifications included
Use Cases
  • Personal document vault with search
  • Team knowledge filing system
  • Receipt & invoice OCR archive
  • Legal documents store & retrieval
  • Research papers & notes indexing
  • Company file inbox for AI knowledge base
Workflow Steps
Step Action Description
1 Telegram Trigger Detects incoming docs/images or /search command
2 Filter File or Search Routes based on whether message has file or search command
3 Extract Metadata Reads file info such as name, MIME type, user
4 Download File Downloads file via Telegram API
5 Upload to Drive Saves file in Google Drive
6 OCR Check Determines if file supports OCR
7 Google OCR Runs OCR for images/PDFs
8 Extract Text Pulls text output from OCR
9 Merge OCR Text Combines file data + text
10 Save to Airtable Indexes with metadata + text
11 Success Reply Sends link + success message
12 /search Flow Parse search query
13 Airtable Search Full-text search for records
14 Send Results Sends matches to Telegram
15 Error Handler Notifies user on failure
Input Formats
File Messages Supported
  • Images
  • PDFs
  • Documents
Search Command
/search keyword
Example:
/search invoice
Output
After Upload:
✅ File saved & indexed successfully!
🔗 Drive Link: <link>
After Search:
Returns structured result:
  • File name
  • Preview text snippet
  • Google Drive link
Data Stored in Airtable
Field Description
File Name Original name
File Link Google Drive link
MIME Type File type
Telegram User Sender info
OCR Text Extracted searchable text
Uploaded Date Timestamp
Technical Requirements
  • Telegram Bot Token
  • Google Drive API connection
  • Google Vision API key
  • Airtable API key & table
Benefits
  • Automatically organizes Telegram files
  • Makes PDFs & images searchable
  • Saves manual sorting and indexing time
  • AI-ready data storage (future LLM integration)
  • Fast search experience right in Telegram
Enhancement Ideas
  • Add Whisper for voice message transcription
  • Add chat GPT summarization for large docs
  • Build dashboard for uploaded files
  • Auto-tag documents (invoice, ID, receipt etc.)
  • Multi-language OCR support
Status
✅ Ready for production
✅ Handles images, PDFs, and files
✅ End-to-end automation
🛠 Optional: add more AI enrichment later
