PartnerStack/Impact → WooCommerce product creation with GPT-4 & AI images
Created by: Amjid Ali || amjid
Amjid Ali
Last update a month ago
🚀 PartnerStack/Impact → WooCommerce (AI-Powered Product Automation)
Turn affiliate programs into fully published WooCommerce products—on autopilot.
This n8n template pulls offers from PartnerStack/Impact (or your own links), generates SEO copy and images with AI, and publishes External products to WordPress/WooCommerce—hands-free.
🎯 What This Automation Does
  • Runs on a schedule (e.g., daily at 10:00 or every 3 days)
  • 📄 Reads rows from Google Sheets (your affiliate product registry)
  • 🔗 Inserts your affiliate link (PartnerStack/Impact/CJ or manual)
  • 🌐 Fetches product/landing page and parses key details
  • 🤖 Uses AI to create product title, short & long HTML description
  • 🖼️ Creates a product image from an AI image prompt
  • 🗂️ Uploads media to WordPress, sets alt/title/caption
  • 🛒 Creates a WooCommerce External product via REST API
  • 🏷️ Applies category by ID and sets the featured image
  • Marks the row as published to avoid duplicates
  • 🧯 Graceful error handling (failed fetches are flagged & skipped next run)
🛒 Output of Wordpress Website Product:
AI Affiliate Product Automation
🧑‍🏫 Step-by-Step Video Tutorial
🎥 Watch the implementation tutorial:
📌 Live demo: schedule, sheet → product, AI copy/image, REST publish.
🌐 Useful Links
🛠 Prerequisites
  • ✅ n8n (self-hosted or Cloud)
  • ✅ WordPress + WooCommerce with REST API enabled
  • ✅ WordPress Application Password / API credential with media & products scope
  • ✅ OpenAI (or your preferred AI) API key
  • ✅ Google Sheet with minimum columns:
    • AdvertiserIdandCompaignID (unique key)
    • AdvertiserUrl (merchant/product URL)
    • TrackingLink (your affiliate URL)
    • Brand
    • partner_status (e.g., “Active”)
    • product_published (Yes/blank)
    • error (Yes/blank)
📋 Step-by-Step Implementation
1️⃣ Scheduling & Intake
  • Add a Schedule Trigger (daily, every 3 days, or your cadence).
  • Google Sheets → Read: pull rows from your “impact/partnerstack” tab.
  • Filter rows: partner_status = Active AND product_published != Yes AND error != Yes.
  • Limit to 1 per run (safe scaling). Increase later if needed.
2️⃣ Product Discovery & Parsing
  • HTTP Request the AdvertiserUrl to fetch the landing/product page.
  • Parse title/meta/summary; continue on error and flag failures (so runs don’t break).
3️⃣ AI Content Generation
  • Agent 1 – Basics: Product Name, Short Description, Category ID mapping (match your Woo categories).
  • Agent 2 – Long Form: SEO-ready HTML description (H2/H3, bullets, features, benefits, target users, technical highlights).
  • Agent 3 – Image Prompt: Generate a clean product-hero prompt; then AI Image generation.
4️⃣ Media Handling
  • Upload media to WordPress (/wp/v2/media) with title/alt/caption and proper content-type.
  • Capture the media ID for the next step.
5️⃣ WooCommerce Product Creation
  • Create product via POST /wc/v3/products with:
    • type: "external"
    • name, short_description, description
    • external_url: TrackingLink
    • button_text: "Sign Up" (or “Buy Now” / “Get It Now”)
    • status: "publish" (or “draft” if you want manual review)
  • Attach featured image with the uploaded media ID.
  • Set categories by ID (ensure your mapping is correct).
6️⃣ Post-Publish Updates
  • Update the Google Sheet row using the unique key (AdvertiserIdandCompaignID):
    • product_published = Yes
    • Clear/reset any transient error flags.
7️⃣ Error Handling & Idempotency
  • If fetch fails (e.g., Cloudflare/Turnstile), mark error = Yes and skip that row next run.
  • Filter excludes error = Yes and already-published rows—no accidental duplicates.
💰 Optional Monetization & Distribution
  • Blog & Social: Add branches to generate a blog article, LinkedIn/Twitter posts from the same product data.
  • Video: Create a short promo video (Sora/Gen-AI) and auto-schedule to TikTok/YouTube/Instagram.
  • Email: Trigger a campaign (e.g., Brevo/Mailchimp) for new products added this week.
💡 Advanced Customizations
  • Draft workflow: publish products as draft for human QA.
  • Category Mapper: expand the category ID table to fit your Woo taxonomy.
  • Image sizing: add an optional resize/optimize node before upload.
  • Batching: remove the Limit node to publish multiple products per run (respect rate limits).
  • Per-brand theming: vary prompts (tone/structure) based on Brand column.
🧰 Troubleshooting
Issue Fix
WordPress 401/403 Re-create Application Password; ensure correct base URL & permalinks
Image upload fails Check content-type & binary upload settings; verify max upload size on server
Product lacks image/category Confirm media ID capture & category ID mapping
Duplicate items Ensure product_published is set to Yes after success; keep Limit node during testing
Fetch errors on merchant site Keep “continue on error”; route to set error = Yes, then review manually
🙌 Why Use This Template
  • ⏱️ Saves hours of manual listing work
  • 📈 SEO-consistent product pages every time
  • 🧠 AI-quality copy & images with your tone
  • 🔗 Affiliate link everywhere, fully tracked
  • 🛠️ Extensible to blog, social, video, and email
🚀 Get Started Now
Import the template → Connect credentials → Point to your Sheet → Run once → Enable schedule.
Need help or a DFY build? SyncBricks can implement and customize this for your stack.
👉 Amjid Alihttps://linkedin.com/in/amjidali
🌐 Websitehttps://amjidali.com | https://syncbricks.com.au
▶️ YouTubehttps://youtube.com/@syncbricks
Knowledge Base: woocommerce-rest, partnerstack, impact, affiliate-automation, openai, n8n, google-sheets, content-generation, image-generation, wordpress-api, creator-hub
