Create a voice-enabled AI assistant with Groq, SerpAPI and TTS
Last update 11 days ago
What It Does
Build your own AI Chatbot that listens, thinks, searches, and speaks — all inside n8n.
This template combines Groq AI, LangChain Agent, SerpAPI, and StreamElements TTS to create a chatbot that:
  • Understands natural language input
  • Searches the web for real-time answers
  • Remembers previous messages (context memory)
  • Replies with a realistic AI voice
How It Works
  • Chat Trigger: The workflow activates whenever a new message is received.
  • Groq AI Agent: Processes user input, performs reasoning, and integrates with SerpAPI for live web results.
  • Memory Node: Keeps the chat context for a natural conversation flow.
  • TTS Node: Converts AI responses into realistic voice replies using StreamElements API.
Setup Steps
  • Connect your Groq, SerpAPI, and StreamElements credentials (no coding required).
  • Customize the chatbot behavior directly inside n8n.
  • Deploy instantly and chat via webhook or UI widget.
Use Cases
  • Voice-enabled customer-support bots
  • AI chat widgets for websites
  • Personal assistants that talk and search the web
