Create AI meeting summaries with Fireflies transcripts & Dart tasks using Gemini
Created by: Dart || dart-team
Dart
Last update 12 days ago
Automatically generate a meeting summary from your meetings through Fireflies.ai, save it to a Dart document, and create a review task with the meeting link attached.
What it does
This workflow activates when a Fireflies.ai meeting is processed (via a webhook). It retrieves the meeting transcript via the FirefliesAI transcript node and uses an AI model to generate a structured summary.
Who’s it for
  • Teams or individuals needing automatic meeting notes.
  • Project managers tracking reviews and actions from meetings.
  • Users of Fireflies.ai and Dart who want to streamline their documentation and follow-up process.
How to set up
  • Import the workflow into n8n.
  • Connect your Dart account (it will need workspace and folder access).
  • Add your PROD webhook link from the webhook node to your Fireflies.ai API settings.
  • Add your Fireflies.ai API key on the Fireflies Transcript node.
  • Replace the dummy Folder ID and Dartboard ID with your actual target IDs.
  • Choose your preferred AI model for generating the summaries.
Requirements
  • n8n account
  • Connected Dart account
  • Connected Fireflies.ai account (with access to API key and webhooks)
How to customize the workflow
  • Edit the AI prompt to adjust the tone, style, or format of the meeting summaries.
  • Add, remove, or change the summary sections to match your needs (e.g., Key takeaways, Action Items, Summary).
